Just installed the latest version of the toolkit. After running modulefiles-setup.sh I get:
Loading compiler version 2021.2.0
Lmod has detected the following error: /N/soft/modules_devel/bigred200/intel/compiler/2021.2.0: (intel/compiler/2021.2.0): invalid
command name "is-avail"
It looks like is-avail was introduced in environment modules 4.8. Is there any way to use other module environments?
Could you please try using setvars.sh script file to set up the development environment, as module files are alternate to setvars or vars script files.
Refer:
Also please do let us know why you are opting module files for setting up the environment, is there any specific requirement.
Thanks & Regards
Noorjahan.
I'm sure setvars works well, but we use environment modules (specifically lmod).
We administer dozens of packages on a high-performance cluster using modules. Unlike setvars, modules allow you to unload variables in the environment as well as load them.
The issue raised by you will be fixed in next release of oneAPI.
Meanwhile you can try using modules with tcl.
Please refer:
Thanks & Regards
Noorjahan
We use lmod, but thanks.
Can you be more specific about what the fix will be? Will the modules files work with older versions of environment modules?
Environment modules with lmod is currently not supported. The support is expected in the upcoming releases on oneAPI.
As of now tcl modules are supported on oneAPI.
Thanks & Regards
Noorjahan.
Reminder: Could you please let us know if your issue is resolved ? so that we can close this thread from our end.
Thanks & Regards
Noorjahan.
I won't know if the issue is resolved until I see the future oneAPI release that supports LMod.
Apologies for any confusion.
We will keep you posted about the upcoming release when it is fixed.
Thanks & Regards
Noorjahan.
Thanks for your patience.
Lmod feature is enabled in the latest oneAPI release (2021.3.0)
Please refer the below link to install latest oneAPI release:
https://software.intel.com/content/www/us/en/develop/tools/oneapi/base-toolkit/download.html
Please refer below link regarding Modulefiles and it's requirements:
Please update to latest release(2021.3.0) and do let us know your experience.
Thanks & Regards
Noorjahan
Reminder:
Could you please confirm whether your issue is resolved, so that we can close this thread from our end or else please let us know if you get any issues.
Thanks & Regards
Noorjahan.
Yes, close the thread. Thanks!
Thanks for your confirmation.
we are closing this thread as your issue is resolved.
If you require any additional assistance from Intel, please start a new thread.
Thanks & Regards
Noorjahan.
