Intel® oneAPI Base Toolkit
Support for the core tools and libraries within the base toolkit that are used to build and deploy high-performance data-centric applications.
419 Discussions
<VectorAdd sample> How can USM be more performant than Buffers on CPU for both
Anonymous
Not applicable
It's like 150% more performant than the buffer version on my i3-6100.
And 450% more performant than the buffer version on the dedicated GPU.
The buffer version and the OpenMP version do have the same performance tho.
RahulV_intel
Please specify your oneAPI base toolkit version and all the devices that you have used for comparison. (CPU, integrated GPU, discrete GPU)
Also, could you let me know how exactly did you arrive at those comparison numbers?
Rahul
RahulV_intel
Rahul
Anonymous
Not applicable
Intel(R) oneAPI DPC++/C++ Compiler for applications running on Intel(R) 64, Version 2021.1 Beta Build 20201005
CPU: i3-6100
Integrated GPU: Intel® HD Graphics 530 Gen9
Discrete GPU: GTX 1060 3gb (not detected by OneAPI)
Ok nvm, I just mess with the benchmark I did last night.
So on discrete GPU target, I have 500% more FPS with USM than Buffer.
So on CPU target, I have 100% more FPS with Buffer than USM.
I did this benchmark with the project attached.
You can select the device and buffer/USM in Core.hpp
And for comparison with CUDA on my gtx 1060 3gb, I have 300% more FPS than USM on Intel® HD Graphics 530 Gen9
Anonymous
Not applicable
I forgot to mention that I finally have the same performance than with OpenMP, with USM on CPU target.
RahulV_intel
We are forwarding your query to the concerned team since it's related to performance. The team will get back to you shortly.
Rahul
