Intel® oneAPI Base Toolkit
Support for the core tools and libraries within the base toolkit that are used to build and deploy high-performance data-centric applications.
419 Discussions
__m256 not recognized by OneAPI
Anonymous
Not applicable
And all its instruction family.
Viet_H_Intel
since icx is based on LLVM technology and clang doesn't treat __m128 as a struct or union.
So code needs to be changed as t8.cpp
C:\temp>icl t9.cpp
Intel(R) C++ Intel(R) 64 Compiler Classic for applications running on Intel(R) 64, Version 2021.1 Beta Build 20200827
Copyright (C) 1985-2020 Intel Corporation. All rights reserved.
t9.cpp
Microsoft (R) Incremental Linker Version 14.28.29333.0
Copyright (C) Microsoft Corporation. All rights reserved.
-out:t9.exe
t9.obj
C:\temp>t9.exe
1.5
2.5
3.5
4.5
C:\temp>icx t9.cpp
Intel(R) oneAPI DPC+/C+ Compiler Pro for applications running on Intel(R) 64, Version 2021.1 Beta Build 20200827
t9.cpp(11,8): error: member reference base type '__m128' (vector of 4 'float' values) is not a structure or union
V.m128_f32[i] = i + 1.5;
t9.cpp(12,12): error: member reference base type '__m128' (vector of 4 'float' values) is not a structure or union
a = V.m128_f32[i];
2 errors generated.
$ clang++ t9.cpp
t9.cpp:11:3: error: member reference base type '__m128' (vector of 4 'float' values) is not a structure or union
t9.cpp:12:7: error: member reference base type '__m128' (vector of 4 'float' values) is not a structure or union
a = V.m128_f32[i];
2 errors generated.
C:\temp>icx t8.cpp
C:\temp>t8.exe
1.5
2.5
3.5
4.5
C:\temp> notepad t9.cpp
#include <immintrin.h>
#include <iostream>
using namespace std;
int main () {
float a;
__m128 V;
for (int i =0; i< 4; i ++)
a = V.m128_f32[i];
cout << a << endl;
return 1 ;
C:\temp> notepad t8.cpp
#include <iostream>
#include <vector>
int main () {
__m128 a;
float b;
a[i] = i +1.5;
b = a[i];
cout << b << endl;
return 0;
GouthamK_Intel
Thanks for reaching out to us!
Could you please provide steps to reproduce and source code for which you are getting this error.
Also, let us know the oneAPI toolkit version which you are currently using.
Goutham
Anonymous
Not applicable
#include <corecrt_math_defines.h>
#include <corecrt_math.h>
typedef          __int8  Int8;
typedef          __int16 Int16;
typedef          __int32 Int32;
typedef          __int64 Int64;
typedef unsigned __int8  UInt8;
typedef unsigned __int16 UInt16;
typedef unsigned __int32 UInt32;
typedef unsigned __int64 UInt64;
typedef          char*   String;
typedef          float   Single;
typedef          double  Double;
typedef          bool    Boolean;
struct Matrix3D
    union
        struct
            Single   M11, M12, M13, M14;
            Single   M21, M22, M23, M24;
            Single   M31, M32, M33, M34;
            Single   M44, M43, M42, M41;
        __m128 Row[4];
        float Arr[4][4];
    __m256 _Row[4];
    friend Matrix3D     operator*(Matrix3D left, Matrix3D right)
        Matrix3D Res = { 0 };
        __m128   Dst;
        for (Int32 i = 0; i < 4; i++)
            for (Int32 j = 0; j < 4; j++)
                Dst = _mm_mul_ps(left.Row[i], right.Row[j]);
                Dst = _mm_hadd_ps(Dst, Dst);
                Res.Arr[i][j] += Dst.m128_f32[0];
                //result.Arr[i][j] += left.Arr[i][0] * right.Arr[0][j];
                //result.Arr[i][j] += left.Arr[i][1] * right.Arr[1][j];
                //result.Arr[i][j] += left.Arr[i][2] * right.Arr[2][j];
                //result.Arr[i][j] += left.Arr[i][3] * right.Arr[3][j];
        Res._Row[0] = _mm256_broadcast_ps(&Res.Row[0]);
        Res._Row[1] = _mm256_broadcast_ps(&Res.Row[1]);
        Res._Row[2] = _mm256_broadcast_ps(&Res.Row[2]);
        Res._Row[3] = _mm256_broadcast_ps(&Res.Row[3]);
        return (Res);
GouthamK_Intel
Thanks for providing the reproducer code, we are able to reproduce the error which you are facing.
We are escalating this thread to the concerned internal team who will help you in resolving your issue.
Goutham
Viet_H_Intel
icx requires at least /Qxavx to use _m128/_m256 and intrinsic.
However, it gave an error on m128_f32[0]. I've reported this issue to the compiler Developer.
Viet_H_Intel
C:\temp>icl t9.cpp
t9.cpp
-out:t9.exe
t9.obj
C:\temp>t9.exe
1.5
2.5
3.5
4.5
C:\temp>icx t9.cpp
a = V.m128_f32[i];
2 errors generated.
$ clang++ t9.cpp
a = V.m128_f32[i];
2 errors generated.
C:\temp>icx t8.cpp
C:\temp>t8.exe
1.5
2.5
3.5
4.5
#include <iostream>
int main () {
float a;
__m128 V;
a = V.m128_f32[i];
cout << a << endl;
return 1 ;
#include <iostream>
#include <vector>
int main () {
__m128 a;
float b;
a[i] = i +1.5;
b = a[i];
cout << b << endl;
return 0;
Viet_H_Intel
Since we have provided a solution, we are going to close this thread. If you require additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only.
