Intel® oneAPI Base Toolkit
Support for the core tools and libraries within the base toolkit that are used to build and deploy high-performance data-centric applications.
391 Discussions
oneAPI error:Compiler Error, not able to generate hardware for D5005
jimbook
$dpcpp -fintelfpga -Xshardware -Xstarget=intel_s10sx_pac:pac_s10 fpga_compile.cpp -o main.fpga
aoc: Compiling for FPGA. This process may take several hours to complete.  Prior to performing this compile, be sure to check the reports to ensure the design will meet your performance targets.  If the reports indicate performance targets are not being met, code edits may be required.  Please refer to the oneAPI FPGA Optimization Guide for information on performance tuning applications for FPGAs.
For more details, full Quartus compile output can be found in files quartuserr.tmp and quartus_sh_compile.log.
Error: Compiler Error, not able to generate hardware
llvm-foreach:
dpcpp: error: fpga compiler command failed with exit code 1 (use -v to see invocation)
NoorjahanSk_Intel
Since this is a duplicate thread of https://community.intel.com/t5/Intel-oneAPI-Data-Parallel-C/meeting-failure-when-I-compile-code-for-D5005/m-p/1433352#M2657
we will no longer monitor this thread. We will continue addressing this issue in the other thread.
Thanks & Regards,
Noorjahan.
