Intel® oneAPI Base Toolkit
Support for core tools and libraries to build and deploy high-performance data-centric applications
oneAPI open source?
san__frank
According to Intel, oneAPI is open source. Are all the available DPC++ lauguage, libraries and tools open source, and available in source file format? If yes, where are the source stored?
Gergana_S_Intel
Frank, Abhishek provided you links to the compiler sources but I wanted to give you some additional info.
You're correct that we've committed to providing oneAPI as an open, standards-based model.  The oneAPI open specification is available for review here: https://www.oneapi.com/spec/.  It consists of 9 elements: the DPC++ language & library, as well as 7 others that cover various aspects of oneAPI as a model: e.g. math, video, and deep learning APIs, or a hardware-level interface (called Level Zero).  Each element also has links to available open source implementations (example: DPC++ sycl-based compiler that Abhishek gave you, but also the data analytics implementation, etc.)  We're also working on adding an "Implementations" section to the page - hopefully in the next couple of weeks.
The language and associated compiler are certainly important but I wanted to make sure everyone is aware that the goal of the broader oneAPI effort is to deliver a language + all associated library & hw interfaces you might need to develop for accelerators.
~Gergana
AbhishekD_Intel
Hi Frank,
Yes, they are available in source file format. The link to the binary files is https://software.intel.com/en-us/articles/oneapi-repo-instructions
For more details, you can also refer to this thread which will give you all the information related to your post.
-Abhishek
san__frank
Thanks for your reply. The link you provided is for downloading the binary files, not source files. Does this mean oneAPI doesn't open source the source files for DPC++ compiler and API libraries/tools etc.?
AbhishekD_Intel
Hi Frank,
Please, go through this link https://github.com/intel/llvm. It is the source code of the Intel compiler for the SYCL implementation.
You can also go to this link https://github.com/topics/oneapi for more details.
-Abhishek
Gergana_S_Intel
~Gergana
AbhishekD_Intel
Hi Frank,
Has the given solution worked for you?
Do let us know.
Reach out to us if you need any further help.
