Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Innovator
oneAPI sample compilation error on devcloud
I am in error in compiling the examples generated with oneapi-cli in the devcloud environment. Evidence below:
BUG
Tags (1)
Highlighted
We are able to reproduce the error at our end. We will let the concerned team know about this. Thanks for reporting the issue.
Rahul
Highlighted
Innovator
Please,  install libgtk2.0-0 in devcloud for solve the problem... I am stop with my works. Bellow the command.
$ sudo apt-get install libgtk2.0-0
Highlighted
Hi Cabelo, As you suggested, we will let the concerned team know about the libgtk2.0-0 installation across Devcloud nodes. Thanks, Rahul
Highlighted
Hi Cabelo,
Sorry for the late response and dev team is looking at this and see how to fix. This is a deployment issue on DevCloud.
Just a question, from your perspective, you want to use DevCloud to evaluate VPL or you want to use it to develop VPL?
Mark
Highlighted
This issue has been escalated to Engineer to be fixed.
