I don't understand what is the `kvs` parameter in create_communicator.
In this example I see it being used like that
/* create kvs */
ccl::shared_ptr_class<ccl::kvs> kvs;
ccl::kvs::address_type main_addr;
if (rank == 0) {
kvs = ccl::create_main_kvs();
main_addr = kvs->get_address();
MPI_Bcast((void*)main_addr.data(), main_addr.size(), MPI_BYTE, 0, MPI_COMM_WORLD);
else {
kvs = ccl::create_kvs(main_addr);
/* create communicator */
auto dev = ccl::create_device(q.get_device());
auto ctx = ccl::create_context(q.get_context());
auto comm = ccl::create_communicator(size, rank, dev, ctx, kvs);
What are valid values for it?
Thanks for posting in the Intel communities.
kvs_interface defines the key-value store (KVS) interface to be used to establish a connection between ranks during the creation of oneCCL communicator. For more information, please refer to the below link:
Thanks & Regards,
Santosh
Thanks, but the documentation is not helpful.
>>>"I don't understand what is the `kvs` parameter in create_communicator."
The kvs parameter in create_communicator() expects an object of shared_ptr_class<kvs>(key-value store).
To create KVS objects before passing them to create_communicator(), use the below steps:
oneCCL specification defines kvs class as a built-in KVS provided by oneCCL.
1. Retrieve an address of built-in key-value store using the below function: const addr_t& kvs::get_addr() const; which returns kvs::addr_t
The address of the key-value store should be retrieved from the main built-in KVS and distributed to other processes for the built-in KVS creation.
Creating a main built-in key-value store:
Its address should be distributed using an out-of-band communication mechanism and be used to create key-value stores on other ranks using the function: kvs_t environment::create_main_kvs() const; which returns the main key-value store object kvs_t
Example:
if (rank == 0) {
2. Creating a new key-value store from main kvs address using the function: kvs_t environment::create_kvs(const kvs::addr_t& addr) const;
where, addr is the address of the main kvs & the above function returns kvs_t (key-value store object).
Example:
>>>"What are valid values for it?"
We should pass an object instance of shared_ptr_class<kvs>(key-value store) as a value.
Example: ccl::create_communicator(size, rank, dev, ctx, kvs);
Thanks & Regards,
Santosh
We haven't heard back from you. Could you please provide us with an update on your issue?
Thanks & Regards,
Santosh
I assume that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks & Regards,
Santosh
