Intel® oneAPI Base Toolkit
Support for the core tools and libraries within the base toolkit that are used to build and deploy high-performance data-centric applications.
419 Discussions
oneMKL 2023.1 integration with VisualStudio 2022 fails on clean computer
Luis62
When I installed oneMKL 2023.1 in my old computer over Visual Studio 2019 (wuth many old versions of oneMKL, MKL and Intel compilers previouly installed) akk worked fine: my c++ app compiles and runs correctly with oneMKL 2023.1 without any change.
But in my new computer, with Visual Studio 2022 and any intel product previouly installed, oneMKL 2023.1 installation doesn't integrates with VS2022: any 'Intel Libraries for oneAPI' group is created in compiler optiosn, and $(oneMKLIncludeDir), $(ineMKLOmpLibDir) are not defined.
So, with the same C++ app, many .h amd .lib are not found!
Luis62
Finaly, I've added manually the necessary header and lib paths for x86 and x64 configurations.
For example,
$(ONEAPI_ROOT)mkl\latest\include
or
$(ONEAPI_ROOT)mkl\latest\lib\intel64
$(ONEAPI_ROOT)compiler\latest\windows\compiler\lib\intel64_win
I hope next revision I'll have more luck!
PraneethA_Intel
Hi Luis,
Thanks for posting in Intel communities.
Could you please confirm if only the oneMKL-related directories are not defined or if other Intel products are not defined as well?
If other Intel products are not working as well, you could try repairing the Intel oneAPI toolkits by running the installer.exe file in the below path.
"C:\Program Files (x86)\Intel\oneAPI\Installer\installer.exe"
Please get back to us if this issue persists.
Thanks and Regards,
Praneeth Achanta
Luis62
Hi, Praneeth Achanta,
oneMKL is the only Intel oneAPI product I've installed.
As you can see in next image, only $(ONEAPY_ROOT) is defined.
Repairing the installation has no effect.
VisualStudio 2022VisualStudio 2022
PraneethA_Intel
Hi Luis,
It is recommended not to have multiple versions of oneMKL on the same system as it might lead to ambiguity while integrating oneAPI with Visual Studio. Could you please uninstall all oneAPI copies and perform a fresh install using the latest oneMKL available?
Thanks and Regards,
Praneeth Achanta
Luis62
Hi, Praneeth Achanta. Perhaps I didn't explain well:
  1. oneMKL 2023.1 works fine in my old computer, with oneMKL 2022.0 previously installed (and many other old versions uninstalled) in Visual Studio 2019
  2. oneMKL 2023.1 fails in my very new computer with no intel products  of any kind never previously installed, with Visual Studio 2022
  3. In both computers I've also intalled the 32 bits version of oneMKL (with a custom installation of oneAPI Base Toolkit setup)
PraneethA_Intel
Hi Luis,
Please see this link for the versions of Visual Studio Intel oneAPI is compatible with. If you are using an unsupported version of Visual Studio we suggest you use a version of Visual Studio which is compatible with Intel oneAPI.
Thanks and Regards,
Praneeth Achanta
Luis62
My version is:
Microsoft Visual Studio Enterprise 2022
Versión 17.5.4
VisualStudio.17.Release/17.5.4+33530.505
Microsoft .NET Framework
Versión 4.8.09032
Versión instalada: Enterprise
Visual C++ 2022 00476-80000-00000-AA851
Microsoft Visual C++ 2022
Adaptador de prueba para Boost.Test 1.0
Habilita las herramientas de prueba de Visual Studio con las pruebas unitarias escritas para Boost.Test. Los términos de uso y los avisos de terceros están disponibles en el directorio de instalación de la extensión.
Administrador de paquetes NuGet 6.5.0
Administrador de paquetes NuGet de Visual Studio. Para obtener más información acerca de NuGet, visite https://docs.nuget.org/
ASP.NET and Web Tools 17.5.318.41597
Herramientas de Azure App Service v3.0.0 17.5.318.41597
Herramientas de C# 4.5.2-3.23171.7+d17f741546fad2786cbd6394d08619544e53a36d
Los componentes de C# utilizados en el IDE. En función del tipo de proyecto y la configuración, se podría utilizar una versión diferente del compilador.
Herramientas de TypeScript 17.0.20105.2003
Herramientas de TypeScript para Microsoft Visual Studio
Herramientas de Visual Basic 4.5.2-3.23171.7+d17f741546fad2786cbd6394d08619544e53a36d
Los componentes de Visual Basic utilizados en el IDE. En función del tipo de proyecto y la configuración, se podría utilizar una versión diferente del compilador.
Herramientas de Visual F# 17.5.0-beta.23053.5+794b7c259d9646a7eb685dad865aa27da7940a21
Herramientas de Microsoft Visual F#
Microsoft JVM Debugger 1.0
Provides support for connecting the Visual Studio debugger to JDWP compatible Java Virtual Machines
Test Adapter para Google Test 1.0
Habilita las herramientas de prueba de Visual Studio con las pruebas unitarias escritas para Google Test. Los términos de uso y los avisos de terceros están disponibles en el directorio de instalación de la extensión.
Visual Studio IntelliCode 2.2
Desarrollo asistido por AI para Visual Studio.
PraneethA_Intel
Hi Luis,
We have tried installing Visual Studio 2022 17.5.4 (from this link) and Intel oneMKL 2023.1(from this link) on a new Windows system but could not see any integration issues. (Please see attached screenshot)
Thanks and Regards,
Praneeth Achanta
PraneethA_Intel
Hi Luis,
We have not heard back from you. Could you please provide an update on your issue?
Thanks and Regards,
Praneeth Achanta
Luis62
For example,
or
PraneethA_Intel
Hi Luis,
Glad to know your issue was resolved. Please let us know if you need any additional information or if we could go ahead and close this thread at our end.
Thanks and Regards,
Praneeth Achanta
Luis62
As I've said, my solution is not the best one, but it works.
In next version I'll try it agin and I'll come back here to expose the result.
PraneethA_Intel
Hi Luis,
Glad to know your solution is working. Thank you for sharing it with us.
If your issue persists in the next version please post a new question as this thread will no longer be monitored by Intel.
Thanks and Regards,
Praneeth Achanta
