Intel® oneAPI Base Toolkit
Support for core tools and libraries to build and deploy high-performance data-centric applications
oneapi-cli cannot seem to access samples
Maximillia_D_Intel
I'm following the instructions at:
https://software.intel.com/en-us/get-started-with-intel-oneapi-linux-run-a-sample-project-using-the-...
and hit an issue:
optane@optane-Z390-Gaming-Trident-X-Plus-MS-B926:/opt/intel/inteloneapi$ oneapi-cli
2020/01/07 11:36:52 Get http://iotdk-ninja.amr.corp.intel.com/samples-staging/2021.1-alpha02//cpp.json: dial tcp: lookup iotdk-ninja.amr.corp.intel.com: no such host
It seems I can access http://iotdk-ninja.amr.corp.intel.com from inside the Intel firewall, but cannot access externally.
Could it be that the samples staging area is not publicly accessible? Is that intended?
I'm using the tools from l_BaseKit_a_2021.1.2.033_offline.tar
Max
Tom_Ingleby_Intel
The version of the CLI you are using is several months old when the staging server was internal only.Such an old CLI is not expected to work of the Intel network.
RahulV_intel
Thanks for reaching out to us. We are working on this and will get back to you.
Rahul
RahulV_intel
This command seems to work for me from inside Intel firewall as well as outside. I'm able to copy samples to my local directory using "oneapi-cli" and build/run them without any issue. Could you try running this command once again and let us know if its working?
Rahul
Tom_Ingleby_Intel
Maximillia_D_Intel
Thank you Tom and Rahul. I updated and the tool works as specified in the instructions. I consider this issue addressed. Thanks! Max
RahulV_intel
Glad to know that your issue got resolved. We are closing this thread.
