Intel® oneAPI Base Toolkit
Support for the core tools and libraries within the base toolkit that are used to build and deploy high-performance data-centric applications.
409 Discussions
oneapi-cli command can't connect through proxy
reynolds
When running oneapi-cli list, I get the following response
~/data/oneAPI_samples$ oneapi-cli list
2022/09/01 12:33:17 failed to connect to sample aggregator for cpp samples, attempting to use local cache
2022/09/01 12:33:17 operating offline and local cache for cpp samples does not exist
Get "https://iotdk.intel.com/samples-iss/2022.2.0//cpp.json": context deadline exceeded (Client.Timeout exceeded while awaiting headers)
2022/09/01 12:33:27 failed to connect to sample aggregator for python samples, attempting to use local cache
2022/09/01 12:33:27 operating offline and local cache for python samples does not exist
Get "https://iotdk.intel.com/samples-iss/2022.2.0//python.json": context deadline exceeded (Client.Timeout exceeded while awaiting headers)
2022/09/01 12:33:37 failed to connect to sample aggregator for fortran samples, attempting to use local cache
2022/09/01 12:33:37 operating offline and local cache for fortran samples does not exist
Get "https://iotdk.intel.com/samples-iss/2022.2.0//fortran.json": context deadline exceeded (Client.Timeout exceeded while awaiting headers)
Failed to fetch sample index, this *may* be your network/proxy environment.
You might try setting http_proxy in your environment, for example:
Linux/Mac: export http_proxy=http://your.proxy:8080
Windows: set http_proxy=http://your.proxy:8080
no working sample languages configured [cpp python fortran]
But I am able to run the following fine:
wget https://iotdk.intel.com/samples-iss/2022.2.0//cpp.json
I have setup wget to use proxy information to allow it to work.
I have tried configuring https_proxy variable in local enviornment, but makes no difference.
How can I configure oneapi-list command to also use proxy?
reynolds
Nevermind, my local proxy setting was incorrect. Please close this. Solved.
reynolds
HemanthCH_Intel
Glad to know that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks & Regards,
Hemanth
