Intel® oneAPI Base Toolkit
Support for the core tools and libraries within the base toolkit that are used to build and deploy high-performance data-centric applications.
391 Discussions
oneapi-cli "character set not supported"
siquus
:~$ source /opt/intel/oneapi/setvars.sh
:: initializing oneAPI environment ...
:: advisor -- latest
:: intelpython -- latest
:: vtune -- latest
:: tbb -- latest
:: dnnl -- latest
:: mkl -- latest
:: dev-utilities -- latest
:: dpcpp-ct -- latest
:: ipp -- latest
:: daal -- latest
:: mpi -- latest
:: ccl -- latest
:: ippcp -- latest
:: compiler -- latest
:: vpl -- latest
:: debugger -- latest
:: oneAPI environment initialized ::
~$ oneapi-cli
Connecting to online Sample Aggregator, this may take some time based on network conditions
2020/09/16 08:47:31 character set not supported
My system:
:~$ echo $LANG
en_GB.ISO-8859-15
:~$ oneapi-cli version
v0.0.15-28-gbedc4b7e51
:~$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 18.04.5 LTS
Release: 18.04
Codename: bionic
Igor_V_Intel
UTF-8 is the existing widely used standard and we don't plan to support more encodings at this moment. Closing this thread.
RahulV_intel
Can you give it a try by changing $LANG from ISO-8859-15 to UTF-8 ?
Also, if you are working behind a proxy, please set the value of http_proxy/https_proxy (Doesn't seem to be the case from the log)
export http_proxy=http://your.proxy:8080
Let me know how it goes.
Rahul
siquus
Thanks for the quick response! Unfortunately, it won't fix the problem:
$ export LANG=UTF-8
$ echo $LANG
UTF-8
$ oneapi-cli
2020/09/17 10:36:49 character set not supported
$ luit -encoding UTF-8 oneapi-cli
2020/09/17 10:38:56 character set not supported
RahulV_intel
The default settings are stored in /etc/default/locale file.
Run:
cat /etc/default/locale
To view the default locale.
This file can be altered manually using any editor or update-locale tool.
update-locale LANG=en_GB.UTF-8
Try changing LANG value from en_GB.ISO-8859-15 to en_GB.UTF-8. Later, just restart the terminal and run oneapi-cli, to see if the updated setting makes any difference. (Make sure that you type all the hyphens and underscores)
Instead of changing the global setting, I would recommend you to run this command instead: (to have LANG setting just for this command)
LANG=en_GB.UTF-8 oneapi-cli
Let me know if it helps.
Rahul
siquus
Sorry, still doesn't help:
$ sudo update-locale LANG=en_GB.UTF-8
.. new terminal..
:: vtune -- latest
:: tbb -- latest
:: dnnl -- latest
:: mkl -- latest
:: ipp -- latest
:: daal -- latest
:: mpi -- latest
:: ccl -- latest
:: ippcp -- latest
:: vpl -- latest
$ oneapi-cli
2020/09/17 12:39:08 character set not supported
RahulV_intel
How about this command:
Does it work?
siquus
No, but that would have been surprising given it's the same as the $export LANG=UTF-8 I did above, isn't it?
BTW: I do not need this fixed for myself. It's just a bug I found and wanted to report.
RahulV_intel
The reason I had asked you to try is, when I ran the below command:
LANG=en_GB.ISO-8859-15 oneapi-cli
I get the "Character set not supported" error.
But when I change it to:
It works absolutely fine.
Thanks for patiently trying out all the commands (despite being similar), just wanted to be double sure before I consider it as a bug.
Could you please provide your base-toolkit version details?
If you are using the latest beta-09 build, did you by any chance also notice this issue with the older versions?
Meanwhile, you may access the samples on https://github.com/oneapi-src/oneAPI-samples.
Thanks for reporting this issue and thank you very much for your time.
Rahul
siquus
Hi Rahul,
sorry, I hope my last post didn't appear annoyed - that wasn't my intention
I have not tried any of the older version. This is mine:
$ apt-cache policy intel-basekit
intel-basekit:
Installed: 2021.1-2195.beta09
Candidate: 2021.1-2195.beta09
Version table:
*** 2021.1-2195.beta09 500
500 https://apt.repos.intel.com/oneapi all/main amd64 Packages
100 /var/lib/dpkg/status
2021.1-1970.beta08 500
2021.1-1506.beta07 500
2021.1-1113.beta06 500
2021.1-720.beta05 500
2021.1-423.beta04 500
2021.1-85.beta03 500
Thanks!
RahulV_intel
Forwarding this issue to the concerned team. They will get back to you shortly.
Rahul
Igor_V_Intel
