Can I use range<2> for variable declaration like
range<2> optimalLocalSize;
In my code I have compile error as call to deleted constructor of range<2>.
I am compiling the following code.
#include <CL/sycl.hpp> #include <cmath> #include <iostream> /* These public-domain headers implement useful image reading and writing * functions. */ #ifdef _MSC_VER typedef unsigned int uint; #endif #include "stb/stb_image.h" #define STB_IMAGE_WRITE_IMPLEMENTATION #include "stb/stb_image_write.h" class fillGaussian; class GaussianKernel; using namespace cl::sycl; /* It is possible to refer to the enum name in these using statements, used * here to make referencing the members more convenient (for example). */ using co = cl::sycl::image_channel_order; using ct = cl::sycl::image_channel_type; /* Attempts to determine a good local size. The OpenCL implementation can * do the same, but the best way to *control* performance is to choose the * sizes. The method here is to choose the largest number, leq 64, which is * a power-of-two, and divides the global work size evenly. In this code, * it might prove most optimal to pad the image along one dimension so that * the local size could be 64, but this introduces other complexities. */ range<2> get_optimal_local_range(cl::sycl::range<2> globalSize, cl::sycl::device d) { range<2> optimalLocalSize; /* 64 is a good local size on GPU-like devices, as each compute unit is * made of many smaller processors. On non-GPU devices, 4 is a common vector * width. */ if (d.is_gpu()) { optimalLocalSize = range<2>(64, 1); } else { optimalLocalSize = range<2>(4, 1); } /* Here, for each dimension, we make sure that it divides the global size * evenly. If it doesn't, we try the next lowest power of two. Eventually * it will reach one, if the global size has no power of two component. */ for (int i = 0; i < 2; ++i) { while (globalSize % optimalLocalSize) { optimalLocalSize = optimalLocalSize >> 1; } } return optimalLocalSize; } int main(int argc, char* argv[]) { /* The image dimensions will be set by the library, as will the number of * channels. However, passing a number of channels will force the image * data to be returned in that format, regardless of what the original image * looked like. The header has a mapping from int values to types - 4 means * RGBA. */ int inputWidth, inputHeight, inputChannels; /* The data is returned as an unsigned char *, but due to OpenCL * restrictions, we must use it as a void *. Data is deallocated on program * exit. */ const int numChannels = 4; void* inputData = nullptr; void* outputData = nullptr; if (argc < 2) { std::cout << "Please provide a JPEG or PNG image as an argument to this program." << std::endl; } inputData = stbi_load(argv[1], &inputWidth, &inputHeight, &inputChannels, numChannels); if (inputData == nullptr) { std::cout << "Failed to load image file (is argv[1] a valid image file?)" << std::endl; return 1; } outputData = new char[inputWidth * inputHeight * numChannels]; const float pi = std::atan(1) * 4; static constexpr auto stddev = 2; /* This range represents the full amount of work to be done across the * image. We dispatch one thread per pixel. */ range<2> imgRange(inputHeight, inputWidth); /* This is the range representing the size of the blur. */ range<2> gaussianRange(6 * stddev, 6 * stddev); queue myQueue([](cl::sycl::exception_list l) { for (auto ep : l) { try { std::rethrow_exception(ep); } catch (const cl::sycl::exception& e) { std::cout << "Async exception caught:\n" << e.what() << "\n"; throw; } } }); { buffer<float, 2> gaussian(gaussianRange); myQueue.submit([&](cl::sycl::handler& cgh) { auto globalGaussian = gaussian.get_access<access::mode::discard_write>(cgh); cgh.parallel_for<fillGaussian>(gaussianRange, [=](cl::sycl::item<2> i) { auto x = i[0] - 3 * stddev, y = i[1] - 3 * stddev; auto elem = cl::sycl::exp(-1.f * (x * x + y * y) / (2 * stddev * stddev)) / (2 * pi * stddev * stddev); globalGaussian = elem; }); }); /* Images need a void * pointing to the data, and enums describing the * type of the image (since a void * carries no type information). It * also needs a range which describes the image's dimensions. */ image<2> image_in(inputData, co::rgba, ct::unorm_int8, imgRange); image<2> image_out(outputData, co::rgba, ct::unorm_int8, imgRange); myQueue.submit([&](handler& cgh) { /* The nd_range contains the total work (as mentioned previously) as * well as the local work size (i.e. the number of threads in the local * group). Here, we attempt to find a range close to the device's * preferred size that also divides the global size neatly. */ auto r = get_optimal_local_range(imgRange, myQueue.get_device()); auto myRange = nd_range<2>(imgRange, r); /* Images still require accessors, like buffers, except the target is * always access::target::image. */ accessor<float4, 2, access::mode::read, access::target::image> inPtr( image_in, cgh); accessor<float4, 2, access::mode::write, access::target::image> outPtr( image_out, cgh); auto globalGaussian = gaussian.get_access<access::mode::read>(cgh); /* The sampler is used to map user-provided co-ordinates to pixels in * the image. */ sampler smpl(coordinate_normalization_mode::unnormalized, addressing_mode::clamp, filtering_mode::nearest); cgh.parallel_for<GaussianKernel>(myRange, [=](nd_item<2> itemID) { float4 newPixel = float4(0.0f, 0.0f, 0.0f, 0.0f); constexpr auto offset = 3 * stddev; for (int x = -offset; x < offset; x++) { for (int y = -offset; y < offset; y++) { auto inputCoords = int2(itemID.get_global_id(1) + x, itemID.get_global_id(0) + y); newPixel += inPtr.read(inputCoords, smpl) * globalGaussian[y + offset][x + offset]; } } auto outputCoords = int2(itemID.get_global_id(1), itemID.get_global_id(0)); newPixel.w() = 1.f; outPtr.write(outputCoords, newPixel); }); }); myQueue.wait_and_throw(); } /* Attempt to change the name from x.png or x.jpg to x-blurred.png and so * on. If the code cannot find a '.', it simply appends "-blurred" to the * name. */ std::string outputFilePath; std::string inputName(argv[1]); auto pos = inputName.find_last_of("."); if (pos == std::string::npos) { outputFilePath = inputName + "-blurred"; } else { std::string ext = inputName.substr(pos, inputName.size() - pos); inputName.erase(pos, inputName.size()); outputFilePath = inputName + "-blurred" + ext; } stbi_write_png(outputFilePath.c_str(), inputWidth, inputHeight, numChannels, outputData, 0); std::cout << "Image successfully blurred!\n"; return 0; }
- Tags:
- General Support
Hi Nyan,
A small correction in your code. You have declared range<2> optimalLocalSize, but you haven't initialized it. Hence, as a result range<2> delete constructor is being called.
Correction should be as follows:
range<2> optimalLocalSize(0,0); //Instead of range<2> optimalLocalSize; on line number 32
Attaching modified code for your reference. Let us know if you are able to compile/run it.
--Rahul
Hi Nyan,
--Rahul
Thanks a lot.
Hi Nyan,
Let us know if we can close this thread.
--Rahul
Yes please. thank you.
Thanks for the confirmation, Nyan.
