When I tried to set the environment variables on Ubuntu, it fails.
. /opt/intel/oneapi/setvars.sh
gives the following error message
:: initializing oneAPI environment ...
bash: BASH_VERSION = 4.4.20(1)-release
:: ERROR: No env scripts found: No "env/vars.sh" scripts to process.
This can be caused by a bad or incomplete "--config" file.
Can also be caused by an incomplete or missing oneAPI installation.
Can you help me with this?
Hi Dongwook, could you confirm the following with us:
- Did you encounter any installation issues prior to running the .sh file(warning, errors)
- The OS build on which you are installing the Intel® oneAPI Base Toolkit
Hi ArpanB,
There is no error in the installation.
I installed the intel oneAPI Base Toolkit on Ubuntu 18.04 LTS
Thank you,
Dongwook.
Dongwook, thank you for the information.
The toolkit is supported on Ubuntu 18.04 LTS. Please use the command "source" before the path of setvars.sh file. We also suggest you to visit this link> https://software.intel.com/content/www/us/en/develop/documentation/get-started-with-intel-oneapi-bas..., for guidance on this issue.
That is the page I referred to.
So, I tried both commands
source /opt/intel/oneapi/setvars.sh
They give the same message I mentioned before.
Dongwook, we have contacted you privately to continue our support further on this query.
