Hi
Calling shrink_to_fit() on a std::vector that uses the usm_allocator fails to compile.
#include <vector>
#include <CL/sycl.hpp>
using namespace sycl;
const int size = 10;
int main() {
queue q;
// USM allocator for data of type int in shared memory
typedef usm_allocator<int, usm::alloc::shared> vec_alloc;
// Create allocator for device associated with q
vec_alloc myAlloc(q);
// Create std vectors with the allocator
std::vector<int, vec_alloc >
a(size, myAlloc);
a.shrink_to_fit();
return 0;
> dpcpp -fsycl usm_test.cpp
In file included from usm_test.cpp:1:
In file included from /usr/lib/gcc/x86_64-linux-gnu/7.5.0/../../../../include/c++/7.5.0/vector:62:
In file included from /usr/lib/gcc/x86_64-linux-gnu/7.5.0/../../../../include/c++/7.5.0/bits/stl_construct.h:61:
In file included from /usr/lib/gcc/x86_64-linux-gnu/7.5.0/../../../../include/c++/7.5.0/ext/alloc_traits.h:36:
/usr/lib/gcc/x86_64-linux-gnu/7.5.0/../../../../include/c++/7.5.0/bits/alloc_traits.h:554:7: error: no matching function for call to 'swap'
swap(__one, __two);
/usr/lib/gcc/x86_64-linux-gnu/7.5.0/../../../../include/c++/7.5.0/bits/alloc_traits.h:566:7: note: in instantiation of function template specialization 'std::__do_alloc_on_swap<cl::sycl::usm_allocator<int, cl::sycl::usm::alloc::shared, 4>>' requested here
__do_alloc_on_swap(__one, __two, __pocs());
/usr/lib/gcc/x86_64-linux-gnu/7.5.0/../../../../include/c++/7.5.0/ext/alloc_traits.h:98:12: note: in instantiation of function template specialization 'std::__alloc_on_swap<cl::sycl::usm_allocator<int, cl::sycl::usm::alloc::shared, 4>>' requested here
{ std::__alloc_on_swap(__a, __b); }
/usr/lib/gcc/x86_64-linux-gnu/7.5.0/../../../../include/c++/7.5.0/bits/stl_vector.h:1236:17: note: in instantiation of member function '__gnu_cxx::__alloc_traits<cl::sycl::usm_allocator<int, cl::sycl::usm::alloc::shared, 4>>::_S_on_swap' requested here
_Alloc_traits::_S_on_swap(_M_get_Tp_allocator(),
/usr/lib/gcc/x86_64-linux-gnu/7.5.0/../../../../include/c++/7.5.0/bits/allocator.h:232:24: note: in instantiation of member function 'std::vector<int, cl::sycl::usm_allocator<int, cl::sycl::usm::alloc::shared, 4>>::swap' requested here
__c.get_allocator()).swap(__c);
/usr/lib/gcc/x86_64-linux-gnu/7.5.0/../../../../include/c++/7.5.0/bits/vector.tcc:609:48: note: in instantiation of member function 'std::__shrink_to_fit_aux<std::vector<int, cl::sycl::usm_allocator<int, cl::sycl::usm::alloc::shared, 4>>, true>::_S_do_it' requested here
return std::__shrink_to_fit_aux<vector>::_S_do_it(*this);
/usr/lib/gcc/x86_64-linux-gnu/7.5.0/../../../../include/c++/7.5.0/bits/stl_vector.h:742:9: note: in instantiation of member function 'std::vector<int, cl::sycl::usm_allocator<int, cl::sycl::usm::alloc::shared, 4>>::_M_shrink_to_fit' requested here
{ _M_shrink_to_fit(); }
usm_test.cpp:20:5: note: in instantiation of member function 'std::vector<int, cl::sycl::usm_allocator<int, cl::sycl::usm::alloc::shared, 4>>::shrink_to_fit' requested here
a.shrink_to_fit();
/usr/lib/gcc/x86_64-linux-gnu/7.5.0/../../../../include/c++/7.5.0/bits/move.h:210:5: note: candidate template ignored: could not match '_Tp [_Nm]' against 'cl::sycl::usm_allocator<int, cl::sycl::usm::alloc::shared, 4>'
swap(_Tp (&__a)[_Nm], _Tp (&__b)[_Nm])
/usr/lib/gcc/x86_64-linux-gnu/7.5.0/../../../../include/c++/7.5.0/bits/stl_pair.h:495:5: note: candidate template ignored: could not match 'pair' against 'usm_allocator'
swap(pair<_T1, _T2>& __x, pair<_T1, _T2>& __y)
/usr/lib/gcc/x86_64-linux-gnu/7.5.0/../../../../include/c++/7.5.0/bits/stl_pair.h:503:5: note: candidate template ignored: could not match 'pair' against 'usm_allocator'
swap(pair<_T1, _T2>&, pair<_T1, _T2>&) = delete;
/usr/lib/gcc/x86_64-linux-gnu/7.5.0/../../../../include/c++/7.5.0/bits/move.h:187:5: note: candidate template ignored: requirement '__and_<std::__not_<std::__is_tuple_like<cl::sycl::usm_allocator<int, cl::sycl::usm::alloc::shared, 4>>>, std::is_move_constructible<cl::sycl::usm_allocator<int, cl::sycl::usm::alloc::shared, 4>>, std::is_move_assignable<cl::sycl::usm_allocator<int, cl::sycl::usm::alloc::shared, 4>>>::value' was not satisfied [with _Tp = cl::sycl::usm_allocator<int, cl::sycl::usm::alloc::shared, 4>]
swap(_Tp& __a, _Tp& __b)
1 error generated.
Thanks for reaching out to us!
We are forwarding this thread to the concerned internal team.
Have a Good day!
Thanks & Regards
Goutham
Maybe it is a bug need to be fixed. Have escalated it to the development team.
Hi Jamil,
This issue has been fixed in the latest compiler (2021.3). You can download and install the latest oneAPI from website https://software.intel.com/content/www/us/en/develop/tools/oneapi/base-toolkit/download.html?operati....
I have verified with the latest compiler. Could you verify again?
We haven't heard back from you for a long time, and this issue has been fixed in the new compiler. We will no longer respond to this thread. If you require additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only.
