Intel® oneAPI Base Toolkit
Support for the core tools and libraries within the base toolkit that are used to build and deploy high-performance data-centric applications.
419 Discussions
the oneapi linker for version 2023.1.0 issues alot of noise
MXG
When we build a c++ app with the oneapi 2023.1 we get a lot of noise (binary chars):
qba_to_gpm_files.dir\Release\convert_qba_to_tectonic.obj
qba_to_gpm_files.dir\Release\convert_qba_to_erosion.obj
qba_to_gpm_files.dir\Release\convert_qba_to_json.obj /Qoption,link,/machine:x64 -qnextgen
119>xilib: : warning #10006: ignoring unknown option '¢snåg¢st4ded4enelcgktd12ttrtsf4eåordpgty4y.4de45f44ent4d|dh8ree55tnn4rdsnt4g44rsteet44ene4el4ersfgfd(dorr4es334eodfdeò4t|"nn4nrnrlnr4ee4"eòe"endndd42244d4tm4rs44tressrn44dny4doe444n4e4edmdeeee4d41ee4"3-pph4nen4e44eh3e4h"ete4ens"s44tneee-qdqe4d4dd4t44eedsslddd4se4err4t4trrrrnr4rea2n4lmdent24te446d4yòto4òo4rhh444reoòdeeeeeqgds7s4901vs44d67n9012345678lsdrre4ncerdnh4h4"4hnnt4wse44sn4ns4s44srs4fòggd4deeetd-4ten4t4eyss4gad4ee4n=44eetrn4dn4g4sd4-e4d4de"d4dndryn4n4)4e44eesee-s4)ks4d3456n8eòelelts4dd4ddssts4tsd4dd8yyr464l44tn4:rsn'6ls)sn444:s44nyònr-e4rt4d44drr44rdòn4nrd44dn'snwòeeòe84d44)sm=)4dsssr-d4dr44rr79dòd4dmd6nt8ne1444w4yd4r944e4-)-4-4)r4l5dnò4m)4smet44tdd4n'ssn424:n24n4d5q6n8eòy4d4dttd4e4t~tmgt4s7-4se1ngdd:7p8pnnr444d=4d-4e8n4g44ndr)-n44g44ye40-ò3ne464ny4d4dd1dd45eg)4errn44284d4ndn44ense2e4de44t44t4tòtspròòm44ne0p14pr44rrte4nn1¢4¢t4e4qrnn--t-44n44edtd-404-sn¢67d44 9012tss4s0ts234567+s+scet4eedeere4s4ne44:s44r4ntte43g¢¢89nssr456-4eneh"qet4ennh-4yed4d-d4e...
L91356FR.913I48G¢/¢DHDXP5446802444/PF¢åE¢HEEG/¢DGDEE4/DP4D-eYSSCn4DD.4sA4nG44e4DE844O8444.Y345M6789E.A.44...ERRLCC4T¢¢e4HTEE4QT¢EWGEC68LPTESE012UZLeG4D/4dgEEEDE/.HP4R4R¢¢4¢¢4SD>1440244.74480413579135..448044.2354..8014.45..80.23.5791344444.680░.3446474489...44344.7.901234444.78901234567890123456.7.89╖.123456.90123.4567.89.01234.56.7.8-444.644.044.54.6.784.901.9.01.3.4.5674.90.12.54.674.844.0.14.244.674.234.94.014.24.3444.4.5.67.84.3.4.56789å.0123454å44.4567890123456747.14.56784.904.34444.1.24.8.9.04.12.3.94.04.144.4564.74.89014.44.5.0.1.244.84.01.234.56.789.01234.678901244.89012/àx3.456.78.044.44.8.0.1.2.64.84.2░.67.8.014.23.444.5.6.9e0.144.64.34.56.8.1.2347.454.8.9.23444.744.0123456.7844.24.6789.0.12.3.4567444.890124.044.234/4.0123.4.5.64.9.01.345.6.78.9.0.14444.14.674.8444.84.64/.64.012.345678904.1.3.44.012.34567894.123456789044.45.6.7.8944.34.8.901234564.7844.14.24.345678904.144444.1234t012.3.9014.23454.6789012344.8444.345.6789014444/.64.78901.2.3.456.7.8.9.0.1.244.674.3484444.012444.894ë8.23.647....
egees¢4se4¢l44)y+sedfkef:.eed4di444)sr4de444pgnatderg4ªty4ddt░4.TnLnsG""4kG444s-NtHDN4.òt1444tR4dTtR4HEEe2444░N24n44TdR¢.4.E888.D░..44R1D4.R444R.S.░S4DED¢.T¢EE¢R¢..R¢8.░8.R¢N.DEE4DDDX8SRPsRs8H4eD4mE.LLEdFHEEsY4(sSMGH(sGGDDDE.D.sE4(s4D-4E4eE░4L-4=BEEòEBBBBTDD.A¢HsNS.d1CDHnNtD░KYD2DS¢T44¢-4¢L-4¢eCP-4¢4x-4¢x-4¢d¢dETN-4¢4nTNOO-4¢4eM-4¢SA4dgPD-4¢y-D░4¢4e░4¢ ░4¢PPp░4¢kD/D/DDDDDlDlDDDDdDD-5E¢4e4hr¢4HRrDN-░░E░░N/TN4¢PDFO4¢x4¢4dN░e4¢sNNd4¢4nNNNNNm-4¢dSGHdSyssREEKsT1(░2('░OT4RSPPP¢dVVEsDnPDTNS-4¢LN4¢rååråå] å4¢]råå å4¢ å4¢rråå░]rrråå░] å4¢råå]sETTECX4EsHDd-4¢4dLOE-4¢4dNEXCDD-4¢dEE░YnL/DD. s 44t 4t 4t 44tRYååå ååå åååRåååsCåååDååå ååågVåååy ååå åååe åååNåååNTåååOåååoEeNC>NneCC> åååtRååån åååt ååånRåååyNåååNNåååN░dN4¢ R░)R░)░7LdL░4¢ M░)░4¢ rY░-4L░¢ Y░--S4L4¢ ¢ L¢ SL4¢ ¢ S4¢ L¢ S¢ L¢ L¢ L¢ S¢ L¢ S¢ -¢ T¢ T4M¢ HS¢¢ ¢ ░░¢ D¢ DB¢ M4-StStGnElG48e484¢8d414tnYsDDE'4L4nX4t+]GtY4tT░4ETRTEg4D4e44s4sDDDT
Morten Gaupaas
MXG
I am not able to reproduce this in a simpler system - but the output is not showing when we are using the msvc linker - only the intel linker:
2023-04-24T12:32:36.1169927Z     27>Link:
2023-04-24T12:32:36.1171107Z          C:\Program Files (x86)\Intel\oneAPI\compiler\2023.1.0\windows\bin\Intel64\xilink.exe -qm64 /OUT:"F:\agent2\_work\4\s\build\test\StaticLibraries\MathLib\Release\MathLib_test.exe" /INCREMENTAL:NO /NOLOGO ..\..\..\src\StaticLibraries\MathLib\source\Release\MathLib.lib ..\..\..\src\StaticLibraries\GPACommon\source\Release\GPACommon.lib kernel32.lib user32.lib gdi32.lib winspool.lib shell32.lib ole32.lib oleaut32.lib uuid.lib comdlg32.lib advapi32.lib /MANIFEST /manifest:embed /MANIFESTUAC:"level='asInvoker' uiAccess='false'" /PDB:"F:/agent2/_work/4/s/build/test/StaticLibraries/MathLib/Release/MathLib_test.pdb" /SUBSYSTEM:CONSOLE -qnextgen /TLBID:1 /DYNAMICBASE /NXCOMPAT /IMPLIB:"F:/agent2/_work/4/s/build/test/StaticLibraries/MathLib/Release/MathLib_test.lib" /MACHINE:X64 MathLib_test.dir\Release\coordinate_sys_test.obj  /Qoption,link,/machine:x64
2023-04-24T12:32:36.2398635Z     27>xilink: : warning #10006: ignoring unknown option '¢snåg¢st4ded4enelcgktd12ttrtsf4eåordpgty4y.4de45f44ent4d|dh8ree55tnn4rdsnt4g44rsteet44ene4el4ersfgfd(dorr4es334eodfdeò4t|"nn4nrnrlnr4ee4"eòe"endndd42244d4tm4rs44tressrn44dny4doe444n4e4edmdeeee4d41ee4"3-pph4nen4e44eh3e4h"ete4ens"s44tneee-qdqe4d4dd4t44eedsslddd4se4err4t4trrrrnr4rea2n4lmdent24te446d4yòto4òo4rhh444reoòdeeeeeqgds7s4901vs44d67n9012345678lsdrre4ncerdnh4h4"4hnnt4wse44sn4ns4s44srs4fòggd4deeetd-4ten4t4eyss4gad4ee4n=44eetrn4dn4g4sd4-e4d4de"d4dndryn4n4)4e44eesee-
Could some of the linker arguments cause these problems?
Morten
ShivaniK_Intel
Thanks for posting in the Intel forum.
Could you please provide us with the sample reproducer and steps to reproduce the issue at our end?
Could you also provide us with the OS details and output of lscpu command?
Thanks & Regards
Shivani
MXG
The build is running on Azure Devops on Windows with Windows 10 , VS 2019 C++, Intel C++ 2023.1.
The build us set up to use Intel C++ 2023.1 for the compile/linking - I will try to reproduce this in a smaller sample.
Morten
MXG
Morten
ShivaniK_Intel
Could you please let us know whether your issue is resolved as you accepted it as a solution?
Thanks & Regards
Shivani
MXG
I am not able to reproduce this for a simple model - only on azure devops - so if this is not reported by others we can only put it to rest.
Morten Gaupaas
ShivaniK_Intel
Since the issue is not reproducible on a simple model but only on Azure DevOps, we are closing this thread for now. We kindly request that you create a new thread when you are able to reproduce the issue.
Please note that this thread will no longer be monitored by Intel. If you require further assistance, please feel free to post a new question.
Thanks & Regards
Shivani
