Intel® oneAPI DL Framework Developer Toolkit
Get answers for developing new or customizing existing frameworks using common APIs.
I want to run oneDNN on GPU
k_higashi
Please teach me the steps to run the oneDNN sample code on a GPU (DPC ++).
I have confirmed that it works on the CPU by following the steps below.
I have created a project by selecting oneDNN CNN FP32 Inference from Browse Intel oneAPI Samples in the Visual Studio IDE.
I run it referring to the contents of README.md.
step1 setup.
"C:\Program Files (x86)\intel\oneapi\setvars.bat" --dnnl-configuration=cpu_vcomp
step2 cmake
mkdir build
cd build
cmake -G "Visual Studio 16 2019" ..
cmake --build .
step3 run
bin\Debug\cnn-inference-f32-cpp.exe
The code will be run, but on CPU.
Use time: 15.12 ms per iteration.
Example passed on CPU.
Also, if you specify the gpu option in step 4, the following error will be displayed.
" Application couldn't find GPU, please run with CPU instead."
I think the error is wrong because other samples, such as Vector Add, can be run on the GPU.
I think this procedure was compiled with MSVC. (cpu only)
I want to build and run oneDNN sample code on GPU (DPC ++).
<Information>
OS: Windows 10 Home
Toolkit:
Microsoft Visual Studio 2019 Professional (ver.16.7.7)
Intel oneapi beta 10
Compiler: Intel oneAPI DPC++ Compiler (2021.1.2288)
CPU: Intel Core i7-1065G7 1.3GHz
Accelerator:Iris Plus Graphics
driver ver.: 27.20.100.8681
best regard.
RahulV_intel
We are redirecting your query to an appropriate forum for a faster response.
Rahul
AthiraM_Intel
We are able to reproduce the issue. We are forwarding your case to Subject matter Experts.
