Bug in usm_allocator.hpp max
s1232
Hi Intel Support,
In the DPC++ release 2022.2.1, there is a bug.
I believe this should be using std::max instead (https://en.cppreference.com/w/cpp/algorithm/max).
In file included from /opt/intel/oneapi/compiler/2022.2.1/linux/bin-llvm/../include/sycl/CL/sycl/usm.hpp:11:
/opt/intel/oneapi/compiler/2022.2.1/linux/bin-llvm/../include/sycl/CL/sycl/usm/usm_allocator.hpp:119:50: error: use of undeclared identifier 'max'; did you mean 'fmax'?
  constexpr size_t getAlignment() const { return max(alignof(T), Alignment); }
/usr/include/x86_64-linux-gnu/bits/mathcalls.h:329:14: note: 'fmax' declared here
__MATHCALLX (fmax,, (_Mdouble_ __x, _Mdouble_ __y), (__const__));
Can you please fix this?
Thank you.
S
SeshaP_Intel
Could you please share the sample reproducer code and steps to reproduce so that we can investigate the issue more from our end?
Thanks and Regards,
Pendyala Sesha Srinivas
SeshaP_Intel
We haven't heard back from you. Could you please provide an update on your issue?
Thanks and Regards,
SeshaP_Intel
We have not heard back from you. This thread will no longer be monitored by Intel. If you need further assistance, please post a new question.
Thanks and Regards,
