x86-64 icx 2025.3.1 and older versions.
With just "-O2" the following program:
#include <cmath>
double fn_test(double x, double y, double z) {
return std::fma(x, y, z);
}is translated into:
fn_test(double, double, double):
mulsd xmm0, xmm1
addsd xmm0, xmm2
retwhich is totally wrong. Per the C++ std::fma specification, "Computes x * y + z as if to infinite precision and rounded only once to fit the result type."
The infinite precision is being lost with the sequence listed above. The compiler should emit a call to a library function that emulates FMA correctly on the targets missing that instruction, as e.g. clang does:
jmp fma@PLT
Severity: very high, as techniques like double-double immediately fail due to incorrect rounding.
This is due to the fact that floating-point calculations use different default settings than Clang.
By default, icx enables -fp-model=fast. Compiling with -fp-model=precise, you would see:
jmp fma@PLT # TAILCALL
Likewise, if you compile with clang -O2 -ffp-model=fast you would see:
mulsd xmm0, xmm1
addsd xmm0, xmm2
ret
Thank you. This default is very dangerous, but otherwise your remark is valid.
