Compiler bug, checked on 2025.2.1 2025.3
DmitriSycl
A simple program with SYCL kernel, running on CPU produce incorrect result (works fine running on GPU):
#include <sycl/sycl.hpp>
#include <stdio.h>
sycl::queue q(sycl::cpu_selector_v);
struct st {
    int64_t a;
    int64_t b[64];
void OffendingFunction(st *base)
    q.parallel_for(1, [=](auto i) {
        int n = 64-base[i].a;
        for(int p=0; p<n; ++p) base[i].b[p]=0;
    }).wait();
int main(void)
    uint64_t *arr = sycl::malloc_device<uint64_t>(5000, q);
    q.parallel_for(5000, [=](auto i) { arr[i] = 1; }).wait(); // 4000 works, 5000 does not
    uint64_t tmp;
    q.memcpy(&tmp, arr, sizeof(uint64_t)).wait();
    printf("should equal 1: %llu\n", tmp);
    return 0;
Compile and run:
D:\SYCL-testing>icx -fsycl fill-test.cpp
Intel(R) oneAPI DPC++/C++ Compiler for applications running on Intel(R) 64, Version 2025.3.0 Build 20251010
Copyright (C) 1985-2025 Intel Corporation. All rights reserved.
D:\SYCL-testing>fill-test
should equal 1: 0
What fixes the issue (any line works):
- Commenting out OffendingFunction() (which is not even called)
- Reducing parallel_for in main to 4000
- Adding cast to (int) before assigning to n: int n = 64-(int)base[i].a;
- Or changing assignment to n to a simpler one: int n = base[i].a;
Apparently, OffendingFunction cause no troubles at compile time, but somehow wrecks havoc at runtime.
