Compiler emits invalid byte sequence
hyungseok
I discovered that the latest x86-64 ICX 2024.0.0 emits invalid registers when it generates x86 binaries.
This error has been identified in 16 opcodes.
Buggy code.
/* Type your code here, or load an example. */
void bug(int num) {
__asm__(
".intel_syntax noprefix\n"
"cmpbxadd DWORD PTR [1], EDI, EBP\n" ".align 32\n"
"cmplexadd DWORD PTR [1], EDI, EBP\n" ".align 32\n"
"cmplxadd DWORD PTR [1], EDI, EBP\n" ".align 32\n"
"cmpnbexadd DWORD PTR [1], EDI, EBP\n" ".align 32\n"
"cmpnbxadd DWORD PTR [1], EDI, EBP\n" ".align 32\n"
"cmpbexadd DWORD PTR [1], EDI, EBP\n" ".align 32\n"
"cmpnlxadd DWORD PTR [1], EDI, EBP\n" ".align 32\n"
"cmpnoxadd DWORD PTR [1], EDI, EBP\n" ".align 32\n"
"cmpnpxadd DWORD PTR [1], EDI, EBP\n" ".align 32\n"
"cmpnsxadd DWORD PTR [1], EDI, EBP\n" ".align 32\n"
"cmpnzxadd DWORD PTR [1], EDI, EBP\n" ".align 32\n"
"cmpoxadd DWORD PTR [1], EDI, EBP\n" ".align 32\n"
"cmppxadd DWORD PTR [1], EDI, EBP\n" ".align 32\n"
"cmpsxadd DWORD PTR [1], EDI, EBP\n" ".align 32\n"
"cmpzxadd DWORD PTR [1], EDI, EBP\n" ".align 32\n"
Compile Option: -m32
Compiled Code
bug:
push ebp
mov ebp,esp
mov eax,DWORD PTR [ebp+0x8]
(bad)
cmp eax,0x1
data16 data16 data16 data16 data16 nop WORD PTR cs:[eax+eax*1+0x0]
xchg ax,ax
(bad)
cmp eax,0x1
nop DWORD PTR [eax+eax*1+0x0]
(bad)
cmp eax,0x1
(bad)
cmp eax,0x1
(bad)
cmp eax,0x1
(bad)
cmp eax,0x1
(bad)
cmp eax,0x1
(bad)
cmp eax,0x1
(bad)
cmp eax,0x1
(bad)
cmp eax,0x1
(bad)
cmp eax,0x1
(bad)
cmp eax,0x1
(bad)
cmp eax,0x1
(bad)
cmp eax,0x1
(bad)
cmp eax,0x1
(bad)
cmp eax,0x1
pop ebp
ret
I tested it through godbolt.
Alex_Y_Intel
I've escalated your issue to our internal engineering team
Alex_Y_Intel
This has been fixed in version 2024.1
http://cmplrexplorer.intel.com/z/3qfb4e
