888 Discussions
DPC++ item's id error in the kernel function
shenuo
gpu_selector gs;
cpu_selector cs;
queue Q(cs);
queue Q2(gs);
event ev = Q.submit([&](handler& h) {
auto out = sycl::stream(1024, 1024 * 2, h);
h.parallel_for(nd_range(range{960, 540}, range{ 2,2 }), [=](nd_item<2> it) {
out << it.get_global_id()[0] << " " << it.get_global_id()[1] << "\n";
ev2.wait();
when use Q2, the id output is not reasonable, while Q1 is correct. it seems the has relationship with gpu.
could any one tell me what's wrong here.
my gpu is UHD630, cpu is Intel(R) Core(TM) i7-10610U CPU
OS is win10, IDE is VS2019.
HemanthCH_Intel
Could you please provide the screenshots of expected results and observed results?
Thanks & Regards,
Hemanth
shenuo
thanks for your reply.
just give you one piece of the result :
2488645 0
2488645 1
2488646 0
2488646 1
1251528 2
1251528 3
1251529 2
1251529 3
37765 2
15048 0
37765 3
37766 2
15048 1
37766 3
15049 0
15049 1
you can see the value first dimension is wrong, for the max value is just 960 !
shenuo
  I think this must be related to the graphics or driver problem.
  I find it works fine on another machine
HemanthCH_Intel
Glad to know that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks & Regards,
Hemanth
