836 Discussions
DPC++ sample program execution is leading to segmentation fault in Elkhartlake platform
sumana
I am trying to execute DPC++ Sample program https://github.com/oneapi-src/oneAPI-samples/tree/master/DirectProgramming/DPC%2B%2B/DenseLinearAlgebra/vector-add on Elkhartlake platform (Intel Atom processor) with GPU as device selector.
We are receiving Segmentation fault on executing the above program. The same program works fine when CPU is chosen as device selector. I have executed the same program on ADL and TGL platform.
Could you please let me know if DPC++ is supported for the EHL platform? If yes, how do i further debug the issue.
Thanks and Regards,
Sumana
NoorjahanSk_Intel
We are working on your issue. We will get back to you soon.
Thanks & Regards,
Noorjahan.
Alex_Y_Intel
Which compiler did you use? Have you tried Intel oneAPI IoT Toolkit?
https://www.intel.com/content/www/us/en/developer/tools/oneapi/iot-toolkit.html#gs.5p54ch
sumana
We have been using oneapi base toolkit.
Alex_Y_Intel
Can you please try Intel oneAPI IoT Toolkit and let us know if the problem still exists?
sumana
I tried again after installing one api iotg toolkit (l_IoTKit_p_2022.2.0.165_offline.sh). I am still facing the segmentation fault on EHL platform
Alex_Y_Intel
Can you please try to reduce the vector size to about 100 and see if the issue still occurs?
sumana
I am still observing the segmentation fault even with vector size 100
Alex_Y_Intel
May I ask if you can see the same issue on Windows platform?
It looks like your machine only has OpenCL backend for your GPU, can you please check if you have Level Zero backend by finding libze* under your /usr directory?
What's the version of your GPU driver?
Can you please also provide your backtrace?
Alex_Y_Intel
Since there's no further update, I'm closing the issue from our site. Please feel free to discuss further with the people in the forum, and open a new issue if necessary.
sumana
Sorry for the delayed response. Level zero is not supported in the EHL platform which we are using. We are using Ubuntu 20.04 OS
Ashishti
I am also getting same issue .  segmentation fault while running sample code on EHL board .
Alex_Y_Intel
I can reproduce it on Elkhart Lake Linux machine, and this issue has been escalated to our developers. We'll work on it internally and get back to you when there's update.
