Intel C++ compiler installer crashes
stefanbanev
Intel C++ compiler installer crashes at the beginning of inhalation after unpacking and the launch of install.exe  , the administrative events reported the following message:
//----------- begin
Faulting application name: install.exe_Intel® Software Setup Assistant, version: 3.5.0.155, time stamp: 0x5f5a2735
Faulting module name: Microsoft.VisualStudio.Setup.Configuration.Native.dll, version: 3.12.2140.44225, time stamp: 0x66e1f9ca
Exception code: 0xc00000fd
Fault offset: 0x000153b3
Faulting process id: 0x4238
Faulting application start time: 0x1DBD0095613E62F
Faulting application path: C:\Users\GPU890m\Downloads\Intel\parallel_studio_xe_2020_update4_composer_edition_for_cpp_setup\install.exe
Faulting module path: C:\ProgramData\Microsoft\VisualStudio\Setup\x86\Microsoft.VisualStudio.Setup.Configuration.Native.dll
Report Id: 70c084cc-98e8-43b2-927f-cd25c3ae275b
Faulting package full name:
Faulting package-relative application ID:
//------------ end
The system is Windows 11 pro 24H2,
Microsoft Visual Studio Professional 2019 Version 16.7.16
Tried to install parallel_studio_xe_2020_update4_composer_edition_for_cpp_setup,
with valid licenses for VS and ICC
CPU Ryzen AI 9 HX 370,  RAM 32GB, ~2TB free SSD
I would appreciate any suggestions how to fix that issue...
George
stefanbanev
The issue has been resolved by uninstalling all apps & components related to VS & ICC. After reboot and installation of the same versions of VS & ICC there is no issue anymore, it runs fine. Sorry for late update. Anyway, thanks for your insightful tip.
stefanbanev
