884 Discussions
Intel(R) Core(TM) Ultra 7 155U cpu 4K 420 10bit encode/decode fps is low
fujianfang
when we use Intel(R) Core(TM) Ultra 7 155U cpu, we met a issue.
 1.decode 4K 420 10bit fps is low, decode fps is only 43.
/opt/intel/media/share/vpl/samples/_bin/sample_decode  h265 -i tm1000v3_2160p5994_20mbps_yuv420p10bit.h265 -gpucopy::on -async 4  -o /dev/null -hw
2.encode 4K 420 10bit  fps is low, encode fps is only 43
/opt/intel/media/share/vpl/samples/_bin/sample_encode h265 -gpucopy::on -p010  -i /tmp/yuv/test.yuv  -o ./test.h265 -w 3840 -h 2160 -dstw 3840 -dsth 2160 -b 30000 -hw -async 4 -lowpower:on -u speed -timeout 60 -device /dev/dri/renderD128
3.but encode 4K 420 8bit fps is high, encode fps is 173
/opt/intel/media/share/vpl/samples/_bin/sample_encode h265 -gpucopy::on  -i /tmp/yuv/4208bit.yuv  -o ./test.h265 -w 3840 -h 2160 -dstw 3840 -dsth 2160 -b 30000 -hw -async 2 -lowpower:on -u speed -timeout 60
onevpl use latest version: 2024Q4 .https://github.com/intel/vpl-gpu-rt/releases/tag/intel-onevpl-24.4.4
Is it a known issue?
os version   ubuntu 24.04
kernel:  6.8.0-53-generic  or 6.11.0-17-generic all  have issue.
