Intel oneAPI/HPC toolkit installation fails
pbart
I am trying to install oneAPI/HPC toolkit on Ubuntu 24.04 (WSL2), however when I run the installer I get the following error message:
Launching the installer...
G++ package is not installed
Intel® oneAPI DPC++/C++ Compiler requires G++. It can be installed with
sudo apt-get install g++ on Ubuntu / Debian
sudo zypper install gcc-c++ on SUSE
sudo dnf install gcc-c++ on CentOS / RHEL / Fedora
g++ is available on $PATH, libstc++ is on $LIBRARY_PATH and the c++ includes can be found on $CPLUS_INCLUDE_PATH - however they are not installed in the standard locations, e.g. /usr/bin/g++
Is it possible to specify the g++ installation to use or otherwise solve this issue or do I need to install g++ in a standard location following the suggestions above?
