Option '-TC'
GisleVanem
Just installed Intel's oneAPI and it's compiler dpcpp.exe.
Trying it to compile a C-project of mine seems impossible w/o a major rewrite.
Seems to me it only supports C++ even when using "dpcpp -TC ...". Rather disappointing.
Many warnings on stuff like "char *p = malloc (len);" causing
error: cannot initialize a variable of type 'char *' with an rvalue of type 'void *'
So what's the option "-TC" really for?
Edit: Switching to icx.exe did the trick.
DitiD_Intel
This option tells the compiler to process all source or unrecognized file types as C source files.
For more information, please refer to the link mentioned below.
https://www.intel.com/content/www/us/en/develop/documentation/oneapi-dpcpp-cpp-compiler-dev-guide-and-reference/top/compiler-reference/compiler-options/compiler-option-details/miscellaneous-options/tc-1.html
Could you please provide us with a sample reproducer along with the compiler version being used so that we can investigate your issue from our end.
Thanks and Regards,
Ditipriya.
GisleVanem
Here is a simple example GNU-makefile (called dpcpp-test.mak) or attached:
------------- 8< --- 8< -----------
CFLAGS = -MD -TC
all: dpcpp-test.exe
dpcpp-test.exe: dpcpp-test.obj
  xilink -out:dpcpp-test.exe $<
dpcpp-test.obj: dpcpp-test.c
  dpcpp $(CFLAGS) -Fo$@ $<
dpcpp-test.c: dpcpp-test.mak
  $(info Generating $@)
  $(file > $@,$(dpcpp-test_C))
define dpcpp-test_C
  // Generated file. DO NOT EDIT!
  #include <stdio.h>
  #include <stdlib.h>
  int main (void)
    char *p = malloc(1000);
    printf ("p: 0x%p\n", p);
    p ? free(p) : ((void)0);
    return (0);
endef
Issuing make -f dpcpp-test.mak, gives:
Generating dpcpp-test.c
dpcpp -MD -TC -Fodpcpp-test.obj dpcpp-test.c
dpcpp-test.c(8,11): error: cannot initialize a variable of type 'char *' with an rvalue of type 'void *'
1 error generated.
Enough said.
DitiD_Intel
DPC++ will support only c++ code from c++ 17 and onwards. Hence -TC option does not work.
It is working with icx and icx in windows works for both c as well as c++ code. So, it is behaving correctly.
Thanks and Regards,
Ditipriya.
GisleVanem
A dpcpp -? lists it as an valid option.  Time to clean-up this options mess?
DitiD_Intel
Could you please confirm the OS you're using?
For windows, /TC is a valid option, however for linux, -TC is not listed as a valid option.
Thanks and Regards,
Ditipriya.
DitiD_Intel
We've not heard back from you. Can you please provide an update?
Thanks and Regards,
Ditipriya.
DitiD_Intel
We have not heard back from you. This thread will no longer be monitored by Intel. If you need further assistance, please post a new question.
Thanks & Regards,
Ditipriya.
