Using DPC++ to create windows Apps.
BrianOBrien1
When I create a new project in VS I Select project templates for DPC++, Windows. There are three.
1) DPC++ Console Application
2) DPC++ Dynamic-Link Library
3) DPC++ Static Library
Why is there no 'Desktop'
I have tried to create a project as a C++ project, then I go into the project settings and setup the right include files, libraries and most importantly switching to the DPC++ compiler, but after doing that my app no longer compiles.
Thoughts?
Alex_Y_Intel
Please try to choose "Empty Project--> give it a "project name," and "location" where you want your project resides, and a "solution name," and hit "create." Then you'll add your source files in "Source Files" directory by right-clicking "Source Files" in your "Solution Explorer" and choose "Add"-->"New Item," then you can give it a filename.c or filename.cpp depending on what you want to write, click "Add" and you can start writing your source code.
