clangd broken command line options
Frank_R_1
System:
Intel oneAPI 2024.2.0
Windows 10/11 and Linux RHEL8
Problem:
We found out that the clangd executable does not work either on Windows or Linux
We need this feature for version detection in our IDE (vs code, clion etc.)
On Windows we get:
clangd --version
clangd.exe: Unknown command line argument '--version'. Try: 'D:\p4ws\repo_cache\software\intel\oneAPI\2024.2.0\windows\compiler\2024.2\bin\compiler\clangd.exe --help'
clangd.exe: Did you mean '--log'?
clangd -v
clangd.exe: Unknown command line argument '-v'. Try: 'D:\p4ws\repo_cache\software\intel\oneAPI\2024.2.0\windows\compiler\2024.2\bin\compiler\clangd.exe --help'
clangd.exe: Did you mean '-j'?
clangd --help
clangd.exe: Unknown command line argument '--help'. Try: 'D:\p4ws\repo_cache\software\intel\oneAPI\2024.2.0\windows\compiler\2024.2\bin\compiler\clangd.exe --help'
clangd.exe: Did you mean '--check'?
Best regards
Frank
Frank_R_1
FYI:
clang-format.exe --help
clang-format.exe: Unknown command line argument '--help'. Try: 'D:clang-format.exe --help'
clang-format.exe: Did you mean '-n'?
Best regards
Frank
Alex_Y_Intel
clangd doesn't come with Intel's oneAPI toolkits. And why is it a compiler issue?
Frank_R_1
Of course it comes with the installation of Intel oneAPI:
C:\intel\oneAPI\2024.2.0\windows\compiler\2024.2\bin\compiler\clangd.exe
The whole llvm clang suite is installed under this path.
I just wanted to transport the information to the Intel developer team, that the command line options are messed up!
Best regards
Frank
Alex_Y_Intel
My apologies, you're right that clangd comes in oneAPI package.
I checked on Linux and Windows; for Linux I'm able to use --help to display a list of help options:
$ clangd --help
OVERVIEW: clangd is a language server that provides IDE-like features to editors.
It should be used via an editor plugin rather than invoked directly. For more information, se e:
https://clangd.llvm.org/
https://microsoft.github.io/language-server-protocol/
clangd accepts flags on the commandline, and in the CLANGD_FLAGS environment variable.
USAGE: clangd [options]
OPTIONS:
Generic Options:
--help - Display available options (--help-hidden for more)
--help-list - Display list of available options (--help-list-hidden for more)
--version - Display the version of this program
clangd compilation flags options:
--compile-commands-dir=<string> - Specify a path to look for compile_commands.json. If path is invalid, clangd will look in the current directory and parent paths of each source file
--query-driver=<string> - Comma separated list of globs for white-listing gcc-compa tible drivers that are safe to execute. Drivers matching any of these globs will be used to e xtract system includes. e.g. /usr/bin/**/clang-*,/path/to/repo/**/g++-*
clangd feature options:
--all-scopes-completion - If set to true, code completion will include index symbol s that are not defined in the scopes (e.g. namespaces) visible from the code completion point . Such completions can insert scope qualifiers
$ clangd --version
clangd version 12.0.1 (Red Hat 12.0.1-4.module_el8.5.0+1025+93159d6c)
--version and --help don't work on Windows.
I'll check with our internal team.
