842 Discussions
dpct not converting cudaStream_t stream to sycl::queue *stream in template instantiation code
Shukla__Gagandeep
This is just to report an issue with dpct that it is not converting cudaStream_t stream to sycl::queue *stream in template instantiation code.
For reference, I noticed it while converting horizontal_path_aggregation.cu file from repo libSGM and in template function "enqueue_aggregate_left2right_path", dpct converted function parameter cudaStream_t stream to sycl::queue *stream. Just after this function body, there is code to instantiate same functions with different template parameters like
template void enqueue_aggregate_left2right_path<64u>(
	cudaStream_t stream);
template void enqueue_aggregate_left2right_path<128u>(
But dpct did not convert the patameter type from cudaStream_t to sycl::queue.
May be you want to look into that.
Gagan
RahulV_intel
Hi Gagan,
Thanks for reporting this bug.
I will escalate this issue to the concerned team.
--Rahul
Anoop_M_Intel
This issue is fixed in the latest oneAPI Update. Below is a simple testcase which we tested this against.
$ cat cudastream.cu
#include<cuda.h>
template<int MAX_DISPARITY>
void foo(cudaStream_t stream);
$ dpct cudastream.cu
NOTE: Could not auto-detect compilation database for file 'cudastream.cu' in '/home/anoop/CUDASTREAM' or any parent directory.
The directory "dpct_output" is used as "out-root"
Processing: /home/anoop/CUDASTREAM/cudastream.cu
Processed 1 file(s) in -in-root folder "/home/anoop/CUDASTREAM"
See Diagnostics Reference to resolve warnings and complete the migration:
https://software.intel.com/content/www/us/en/develop/documentation/intel-dpcpp-compatibility-tool-user-guide/top/diagnostics-reference.html
$ cat dpct_output/cudastream.dp.cpp
#include <CL/sycl.hpp>
#include <dpct/dpct.hpp>
template <int MAX_DISPARITY> void foo(sycl::queue *stream);
