889 Discussions
slight delay when a console application exit
mrusso
I made a console application which print something and then exit, after printing instead of exit immediately, like the same application compiled with other compilers it delays the exit, what would be the reason for that?
mrusso
Ok I found the issue:
Basically before the loop that follows, I have:
v85 = v5 + 1;
v87 = 1;
for ( j = v87; j <= v83; ++j ) //V87 TRAIN FROM, V83 PREDICT TO
  *(int *)(handle + sizeof(int) * j) = *(int *)(byte_4BC818 + sizeof(int) * j);
so I had to move the line v85 = v5 + 1; after the scanf that counts how many values are in the data file, v5 is the counter.
Alex_Y_Intel
Why is it related to Intel DPC++/C++ compiler?
mrusso
The issue seems related to optimization, when turned off, works fine, when turn on, sometime got output and sometime no output but always delay in exit.
Alex_Y_Intel
A reproducer and exact commands used need to be provided for understanding your issue.
mrusso
These are the commands:
icx /QxHOST /Ot /Qansi-alias -Qipo VRA.c -o VRASPEED
icx /QxHOST /O1 /Qansi-alias VRA.c -o VRASIZE
icx /QxHOST /O2 /Qansi-alias -Qipo VRA.c -o VRASPEED1
icx /QxHOST /O3 /Qansi-alias -Qipo VRA.c -o VRAMAXSPEED
icx /QxHOST /Os /Qansi-alias VRA.c -o VRASIZE2
icx /QxHOST /Ot /Qiiansi-alias -Qipo VRA.c -o VRASPEED2
icx /QxHOST /Od /Qansi-alias -Qipo VRA.c -o VRADISABLE ; THIS IS THE ONLY ONE THAT WORKS FINE.
and also tried:
icx /QxHOST /Ot /Qansi-alias -Qipo VRA.c -o VRASPEED -fprofile-instr-generate
VRASPEED 1.txt 3 2
llvm-profdata merge -output=code.profdata default.profraw
icx /QxHOST /Ot /Qansi-alias -Qipo VRA.c -o VRASPEED -fprofile-instr-use=code.profdata
icx /QxHOST /O1 /Qansi-alias VRA.c -o VRASIZE -fprofile-instr-generate
VRASIZE 1.txt 3 2
icx /QxHOST /O1 /Qansi-alias VRA.c -o VRASIZE -fprofile-instr-use=code.profdata
icx /QxHOST /O2 /Qansi-alias -Qipo VRA.c -o VRASPEED1 -fprofile-instr-generate
VRASPEED1 1.txt 3 2
icx /QxHOST /O2 /Qansi-alias -Qipo VRA.c -o VRASPEED1 -fprofile-instr-use=code.profdata
icx /QxHOST /O3 /Qansi-alias -Qipo VRA.c -o VRAMAXSPEED -fprofile-instr-generate
VRAMAXSPEED 1.txt 3 2
icx /QxHOST /O3 /Qansi-alias -Qipo VRA.c -o VRAMAXSPEED -fprofile-instr-use=code.profdata
icx /QxHOST /Os /Qansi-alias VRA.c -o VRASIZE2 -fprofile-instr-generate
VRASIZE2 1.txt 3 2
icx /QxHOST /Os /Qansi-alias VRA.c -o VRASIZE2 -fprofile-instr-use=code.profdata
icx /QxHOST /Ot /Qiiansi-alias -Qipo VRA.c -o VRASPEED2 -fprofile-instr-generate
VRASPEED2 1.txt 3 2
icx /QxHOST /Ot /Qansi-alias -Qipo VRA.c -o VRASPEED2 -fprofile-instr-use=code.profdata
icx /QxHOST /Od /Qansi-alias -Qipo VRA.c -o VRADISABLE -fprofile-instr-generate
VRADISABLE 1.txt 3 2
icx /QxHOST /Od /Qansi-alias -Qipo VRA.c -o VRADISABLE -fprofile-instr-use=code.profdata
mrusso
VRASPEED 1.txt 3 2
VRASIZE 1.txt 3 2
VRASPEED1 1.txt 3 2
VRASIZE2 1.txt 3 2
VRASPEED2 1.txt 3 2
mrusso
Alex_Y_Intel
What is VRA.c ?
mrusso
Alex_Y_Intel
We need to have your VRA.c source file to duplicate your observation and investigate it.
mrusso
to run as vra.exe 1.txt 3 2
Also please note that it works only if optimizations are disabled.
On same other compilers it works even with optimizations.
mrusso
v85 = v5 + 1;
v87 = 1;
