I'm attempting to build an autoencoder in DAAL using the Python API, and have a question about how to formulate the loss layer. The NN is architected to output a vector of the same length as the input vector, and the loss function I would like to use is sum of component-wise squared error. From what I can see it seems like the "Loss Forward" layer is what I need, but I cannot figure out how to set the loss function for this layer; the documentation (specifically https://software.intel.com/en-us/daal-programming-guide-loss-forward-layer) seems to imply this is possible, but does not mention how to actually go about doing it. Is this possible, and if so does anyone know how to do this?
Matt
Hi Matt,
The present version of Intel DAAL for Python does not support custom algorithms including loss layers for neural networks. However, you can implement your own loss layer on C++ side. I’ve attached code samples that demonstrate how to do that:
Please, let me know, if it addresses your request
For more complete information about compiler optimizations, see our Optimization Notice.
