Intel® oneAPI Data Analytics Library
Learn from community members on how to build compute-intensive applications that run efficiently on Intel® architecture.
Coordinate Descent algorithm with non separable non-smooth term
Gusev__Dmitry
Could someone please clarify if the DAAL Coordinate Descent algorithm implementation  works with a not necessary additively separable non-smooth function?
The example below refers to L1 norm as non smooth part of the objective function.
https://software.intel.com/content/www/us/en/develop/documentation/daal-programming-guide/top/algorithms/analysis/optimization-solvers/iterative-solver/coordinate-descent-algorithm.html
I would like to use Coordinate Descent algorithm for more generic not necessary separable non-smooth functions. Any thoughts?
Dmitry
AthiraM_Intel
We have forwarded this case to SME, they will get back to you soon.
Kirill_S_Intel
Hello Dmitry,
Current implementation of Intel DAAL Coordinate Descent optimization solver requires next available results from objective function:
  • component of gradient vector computed for smooth part  of objective function
  • component of hessian matrix diagonal, computed for smooth part of objective function
  • and proximal projection operator result, to handle not smooth part
Coordinate descent (and other solvers) requires composite form of objective function as described common part of iterative solvers:
https://software.intel.com/content/www/us/en/develop/documentation/daal-programming-guide/top/algorithms/analysis/optimization-solvers/iterative-solver.html
Also I'm not sure that proximal projection operator itself is applicable for not separable representation of objective function.
Sorry for long response.
Kirill
Gusev__Dmitry
Thank you Kirill,
  • Can you also take a look at the following topic
        https://software.intel.com/en-us/forums/intel-data-analytics-acceleration-library/topic/856818 ;
        it looks to me as it could be a serious problem with the MSE.  I really need your advice on weather this can be fixed or if there is work around on
        using  SAGA with regularized  MSE
  • As far as the current topic - non-smooth part of the objective function M(theta),  generally, does not have to be separable by coordinates (like L1 norm or coordinate wise box constraints). The SAGA algorithm works perfectly fine with not separable non smooth functions. However, looks like DAAL  coordinate descent can not handle this "non-separable" scenario because it is not implemented as block coordinate descent algorithm.  Probably, it is worth to reflect that in documentation.
Dmitry
Shailen_Sobhee
Hi Dmitry,
We will get back to you on the other thread you linked.
Kind regards,
Shailen
