Intel® oneAPI Data Analytics Library
Learn from community members on how to build compute-intensive applications that run efficiently on Intel® architecture.
223 Discussions
Decision tree model in daal4py runs slower than the sklearn model
tcs_hormazd
When running the daal4py decision tree model on a dataset, we notice that it takes longer to run that the sklearn decision tree model. This observation is unusual, as most of the models we've tested have a faster runtime with the daal4py implementation than the sklearn implementation. Do we know what the cause of the slow performance is for the daal4py decision tree model? Could it be that since the decision tree in daal4py does not have all the same hyperparameters available in the sklearn decision tree model, the daal4py decision tree has a set of default hyperparameters that lead to slower performance (e.g. min_samples_split, max_features, etc. which are adjustable for the sklearn model but not the daal4py model)?
RahulU_Intel
We haven't heard back from you. Did you get any chance to try out the samples from your side. Could you please share with us if you have any update.
Rahul
RahulU_Intel
Thanks for posting in Intel communities. We looked into your case. We are trying to reproduce your issue from our side. Meanwhile could you please share with us the sample you are running and what differences in results you observed while running both the decision tree models.
Thanks and Regards
Rahul
RahulU_Intel
We tried reproducing your issue at our end. We were able to see the performance improvement for daal4py when we compared it with the sklearn. We tried on this sample (https://github.com/intel/scikit-learn-intelex/blob/master/examples/daal4py/decision_tree_classification_batch.py). Could you please share with us the sample reproducer so that we can try the same sample from our side.
Thanks and Regards
Rahul
RahulU_Intel
We haven't heard back anything from you. Could you please confirm if the issue is resolved.
Rahul
tcs_hormazd
Thank you for your reply, and sorry for my delay in the response. I am currently running some tests on my end to compare the two models on different datasets to confirm which datasets a speed-up appears on.
RahulU_Intel
Rahul
tcs_hormazd
Hi. We ran the sklearn model and the daal4py decision tree models on some datasets. We observed a speed-up in some cases and a slowdown in some cases (such as when we used the model within a processing pipeline). We are running more tests to figure out exactly in which situations a speed-up occurs and in which situations a slow-down occurs.
RahulU_Intel
We tried some samples from our side using both stock Sklearn and daal4py on some datasets. We got improved performance for almost all the datasets for the daal4py one. Could you please share with us the results of your observation and the datasets you tried on your side.
Rahul
RahulU_Intel
We haven't heard back from you. Could you please share with us if you have any update.
Rahul
RahulU_Intel
We have not heard back from you. This thread will no longer be monitored by Intel. If you need further assistance, please post a new question.
Thanks and Regards
Rahul
