Intel® oneAPI Data Analytics Library
Learn from community members on how to build compute-intensive applications that run efficiently on Intel® architecture.
Error in running DAAL examples on devloud
RAror6
I am getting this error when I tried to run the oneDAL example codes in the install directory in DevCloud
/opt/intel/inteloneapi/daal/2021.1-2021beta06/include/oneapi/internal/kernel_scheduler_sycl.h:30:22: fatal error: 'level_zero/ze_api.h' file not found
            #include <level_zero/ze_api.h>
The command I ran was: make sointel64 mode=build
Could I get some help fixing this?
I am also having difficulties with linkers. I tried following the manual in the developers guide, but for some reason it is not working. Could i please get some help with this as well?
Thank you!
Nikolay_P_Intel1
Sad to inform, but  this is know limitation with Beta06 release. There are 2 workarounds available.
https://oneapi-src.github.io/oneDAL/notes/issues/2021.1-beta06/level-zero-not-found.html
This problem will be permanently fixed in next release.
RAror6
Thank you for the speedy reply!
Two questions:
1) How do I update my driver? OR
2) Where do insert the command 'export SYCL_BE=PI_OPENCL'
Thank you!
Nikolay_P_Intel1
I think that second option should be easier
Most important part would be setting define - #define DAAL_DISABLE_LEVEL_ZERO
SYCL_BE - just have to be exported in your current env - i.e. in shell
RAror6
Thank you for the helpful reply!
1. The 'SYCL_BE' is missing in the define statement in the linked page on the developer's guide. I was a little confused about that, but now it is sorted out! Thank you
2. Unfortunately, it still gives me the same error. I have tried it multiple times. If i try in the default intallation directory, i get an error of 'recipe for sointel64 failed' but if i copy it to my home directory i get the level_zero error. I am running the command: make sointel64 example=cor_dense_batch
Could I please get some help with this?
Thank you!
AthiraM_Intel
Please follow the below steps:
1.  cd examples/cpp_sycl
2.  vi ./source/covariance/cor_dense_batch.cpp
      Add and save the below command in the above file
3. export SYCL_BE=PI_OPENCL
4. vi makefile
    Remove or comment the below command from the Makefile
     LEVEL0_LIB := -lze_loader
5. make sointel64 example=cor_dense_batch
Hope this helps. If you have any issue please let us know
RAror6
Thank you for your help!
Still not working :/
I found the line LOPTS := -Wl,--start-group -Wl,$(DAAL_LIB),$(EXT_LIB) $(DAAL_PATH)/libdaal_sycl.a $(LEVEL0_LIB) -Wl,--end-group in the makefile and removed the $(LEVEL0_LIB) part from it (in addition to the other line). Still nothing.
What else could be causing this error?
Nikolay_P_Intel1
Do you still getting 'level_zero/ze_api.h' file not found ?
The important action is to add "#define DAAL_DISABLE_LEVEL_ZERO
AthiraM_Intel
Please follow the complete steps:
1. Copy the daal folder to the home directory:
     cp -r /opt/intel/inteloneapi/daal /home/uxxxxx
2.  cd /home/uxxxxx/daal/<version>
3. Setting up oneDAL environment via vars.sh script
    Run the following command:
      source ./env/vars.sh
4. To build and run DPC++ examples:
5. Compile your application without Level Zero support:
      vi /home/uxxxxx/daal/<version>/include/oneapi/internal/kernel_scheduler_sycl.h
   Add and save the below command to the file
6. Disable Level Zero runtime:
7. vi makefile
8. make sointel64 example=cor_dense_batch
Hope this helps. If you face any issue please let us know.
RAror6
Thank you so much! This fixed the error.
My mistake was not adding the define statement in the kernel_scheduler.h file. I was adding it in the source code for _cor_dense.
Thank you again!
AthiraM_Intel
Glad to know that your issue got resolved.
We are closing this case.Please feel free to open a new thread if you have any further queries.
