Intel® oneAPI Data Analytics Library
Community support for building compute-intensive applications that run fast on Intel® architecture.
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
How can SVM support rbf kernel?
Bin
I try to use rbf kernel in SVM classification in C++.
I just modify the DAALExamples code, svm_two_class_dense_batch.cpp,
Line 49: services::SharedPtr<kernel_function::KernelIface> kernel(new kernel_function::linear::Batch<>());
I change it to services::SharedPtr<kernel_function::KernelIface> kernel(new kernel_function::rbf::Batch<>());
However, the prediction result is much lower than linear kernel. Do I miss something?  Also how can I set sigma in rbf kernel used in SVM algorithm?  Thanks!
VictoriyaS_F_Intel
Hello Bin,
It is expected that with the default values of RBF parameter sigma and SVM parameter C you get different or even worse predictions than with linear kernel.
To set sigma parameter change the line with the kernel declaration to:
services::SharedPtr<kernel_function::rbf::Batch<> > kernel(new kernel_function::rbf::Batch<>());
And add this code to set sigma parameter to 100.0:
kernel->parameter.sigma = 100.0;
To get a good accuracy with RBF kernel you have to properly choose sigma and C parameters. There are many techniques that allow to find a good combination of those parameters. An example of a practical approach is a grid search among exponentially varying sequences. For example, try all combinations of sigma = (0.0001, 0.01, 1, 100, 10000) and C = (0.0001, 0.01, 1, 100, 10000).
Victoriya
