Intel® oneAPI Data Analytics Library
Learn from community members on how to build compute-intensive applications that run efficiently on Intel® architecture.
231 Discussions
Intel Server Unavailable after executing this code
Adarsh2
I am on intel dev cloud and using Intel OneAPI. This is my code till now:
# first block of jupyter notebook
import modin.pandas as pd
# second block of jupyter notebook
df = pd.read_csv('dataset/dataset.csv')
df.head()
 output -
# output of second block
UserWarning: Ray execution environment not yet initialized. Initializing...
To remove this warning, run the following python code before doing dataframe operations:
    import ray
    ray.init()
2023-09-01 12:00:16,471 INFO worker.py:1636 -- Started a local Ray instance.
The first block is running properly but, when I am reading my dataset, it is giving me this warning and server unavailable error.
If I use `import pandas as pd`, the code is running fine, but `modin.pandas` is not working. My dataset is ~ 2 GB csv file. Why is this happening???
AthiraM_Intel
We are able to reproduce the issue in Intel DevCloud for oneAPI. We are checking on this internally.
yehudaorel
Hi Adarsh2,
When using Modin on dev cloud the following lines must be called:
import ray
ray.shutdown()
ray.init(_memory=16000 * 1024 * 1024, object_store_memory=500 * 1024 * 1024,_driver_object_store_memory=500 * 1024 * 1024)
Can you please give this modification a try and see if the issue is resolved.
I.e (updated code):
import ray
ray.shutdown()
# third block of jupyter notebook
df.head()
Intel OneAPI samples has a helpful getting started sample with Modin -
https://github.com/oneapi-src/oneAPI-samples/tree/master/AI-and-Analytics/Getting-Started-Samples/IntelModin_GettingStarted
Adarsh2
Thanks for your reply!
But this code is running forever.
yehudaorel
Could you run the following to check the memory size limit on your devcloud account:
ulimit -m
To insure there are no issues in the environment itself, I would also recommend to follow the environment setup steps listed here: https://github.com/oneapi-src/oneAPI-samples/tree/master/AI-and-Analytics/Getting-Started-Samples/IntelModin_GettingStarted#configure-environment
yehudaorel
Hi Adarsh2, were you able to give the oneAPI sample a try? In case of no response in the next couple days, the ticket will be closed due to inactivity.
Igor_Z_Intel
I tried excerpt from oneAPI samples
import numpy as np
array=np.random.randint(low=100, high=100000,size=(2**18,2**8))
np.savetxt("foo.csv", array,delimiter=",")
df=pd.read_csv('foo.csv')
print(df.head)
It works on local machine but not in devcloud
yehudaorel
I believe the issue you are seeing is stemming from a bug in the Ray library. On the dev cloud is is needed to add the following lines as I mentioned in earlier comment:
import ray
ray.shutdown()
Following the configuration and setup instructions here: https://github.com/oneapi-src/oneAPI-samples/tree/master/AI-and-Analytics/Getting-Started-Samples/IntelModin_GettingStarted#configure-environment , I was able to run with no issues.
Please make sure your environment is set-up properly and add the api calls to ray library.
Igor_Z_Intel
at least for ray 2.7 it doesn't seem to work for me
yehudaorel
Can you try to downgrade ray package to 2.6.1:
pip uninstall ray
pip install ray==2.6.1
Please give this a try and re-export the ipykernel to run the notebook.
Igor_Z_Intel
Installing 2.6.1 and using
import ray
ray.shutdown()
 I was able to read dataset.csv, @Adarsh2 can you please try this way?
