Intel® oneAPI Data Analytics Library
Learn from community members on how to build compute-intensive applications that run efficiently on Intel® architecture.
225 Discussions
Intel extension for Scikitlearn error with PCA algorithm
Mostafa-
Our customer was trying to work with PCA algorithm through Intel extension for Scikitlearn, in DevCloud.
The error message reported is:
SKLEARNEX DEBUG: sklearn.decomposition.PCA.fit: patching failed with cause - The shape of X does not satisfy oneDAL requirements: number of features / number of samples >= 2
SKLEARNEX INFO: sklearn.decomposition.PCA.fit: fallback to original Scikit-learn
JaideepK_Intel
We were able to reproduce your issue from our end.
This is a known limitation in the Intel extension for Scikit-learn:
When the number of samples exceeds the number of features (samples > 2*features), both Scikit-learn and the Intel extension for Scikit-learn are going to work, else it is going to throw an error like you mentioned above.
Example:
In your sample if u swap n_features with n_samples i.e if
n_features=1000
n_samples=7000
Then your sample is going to work.
Jaideep
JaideepK_Intel
Example:
n_features=1000
n_samples=7000
Jaideep
Mostafa-
thank you, I replied back to our customer, and waiting their response.
JaideepK_Intel
If this resolves your issue, make sure to accept this as a solution. This would help others with similar issue. Thank you!
Jaideep
JaideepK_Intel
Thanks for accepting our solution. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Jaideep
