Intel® oneAPI Data Analytics Library
Learn from community members on how to build compute-intensive applications that run efficiently on Intel® architecture.
Issues Compiling Intel DAAL Example Code
Al-Heji__Ali
Hello everyone,
I have been trying to compile one of the example source codes using "icl". I have never had issues compiling Intel MKL code by linking to the MKL libraries: icl mkl_code.cpp  mkl_intel_lp64.lib mkl_tbb_thread.lib mkl_core.lib tbb.lib.
The DAAL example code builds perfectly from VS2017, but whenever I tried to compile the code using Intel Compiler in the command line:
 icl lin_reg_qr_dense_batch.cpp daal_core.lib daal_thread.lib tbb.lib
I get the following error:
lin_reg_qr_dense_batch.cpp(31): catastrophic error: cannot open source file "service.h"
  #include <service.h>
compilation aborted for lin_reg_qr_dense_batch.cpp (code 4)
Any help would be appreciated.
Thank you,
Ali
Gennady_F_Intel
This header file you may find out into daalroot\examples\cpp\source\utils\  directory. Please add the paths to this directory or copy both of these header files (error_handling.h service.h ) to the working directory and recompile the code.
Al-Heji__Ali
Thanks for the reply, Gennady. I have added error_handling.h service.h to the code directory.
Now, the new error that I get is:
icl: error #10036: unable to run 'link
Again, thanks for the help.
Ali
