Intel® oneAPI Data Analytics Library
Learn from community members on how to build compute-intensive applications that run efficiently on Intel® architecture.
Linear regression module, issues
Reinhard_M_
 I have examined the linear regression module of the DAAL 2018 (Windows version)
1) In the "single_beta" submodule, the RMS error and the variance are inconsistent, i.e. var(j) != rms2(j)*n/(m-p-1)
IMO, in linear_regression_single_beta_dense_default_batch_impl.i, line #316 should be
 pRms = daal::internal::Math<algorithmFPType,cpu>::sSqrt(div1*pRms);
instead of
 pRms = div1*daal::internal::Math<algorithmFPType,cpu>::sSqrt(pRms);
2) The "group_of_betas" submodule contains an unusual definition of the goodness parameter R2
To my best knowledge, R2 runs from 0 ("no fit") to 1 ("perfect fit"). In the DAAL implementation (and documentation),
R2 runs from 0 ("no fit") to 1/n ("perfect fit"). I don't whether this is a buf or a feature
Shaojuan_Z_Intel
Hi Reinhard, which file are you referring to? thanks
Reinhard_M_
Topic 1: The file is "linear_regression_single_beta_dense_default_batch_impl.i", line #316
Topic 2: IMO, the regression sum of squares RegSS is just the squares and not the mean square. Therefore,
            RegSS != TSS - ResSS;
            In your example, TSS-ResSS ≈ n*RegSS. I think, this is the root cause if the R^2 issue.
Shaojuan_Z_Intel
Thanks for pointing this out. The files are from our GitHub. We will investigate this with our engineering team. Thank you!
Shaojuan_Z_Intel
Hi Reinhard, we are analyzing the question and will get back to you with details. Thanks!
VictoriyaS_F_Intel
Hello Reinhard,
Both of your observations are correct –there are bugs in the quality metrics for linear regression in Intel DAAL 2018 Gold. We will fix them in one of future releases of the library.
