Intel® oneAPI Data Analytics Library
Community support for building compute-intensive applications that run fast on Intel® architecture.
The Intel sign-in experience is changing in February to support enhanced security controls. If you sign in, click here for more information.
Linking DAAL library with dpc++
Ajmeer_Khan
How to link DAAL library with dpc++?
I am trying to compile dpc++ with DAAL library but i am facing some issues.I post my issue below.Can you help me to resolve this issues?
ChithraJ_Intel
Hi Ajmeer,
Please let us know whether your issue is resolved or not. Are you able to run oneDAL sample with DPC++ complier? If so, can we discontinue monitoring this thread?
Regarding the FPGA support, we could observe that you have a different thread with similar content and will address your issue in that thread. Link: https://community.intel.com/t5/Intel-oneAPI-Data-Analytics/Compiling-oneDAL-library-with-dpc/m-p/121...
Chithra
ChithraJ_Intel
Hi Ajmeer,
Could you please follow the below steps to build the DAAL samples with DPC++ complier:
1. Copy the daal folder from inteloneapi folder which is preinstalled in Devcloud to your home folder:
cp -r /opt/intel/inteloneapi/daal /home/uxxxxx/
2. Setting up oneAPI environment via setvars.sh script:
source /opt/intel/inteloneapi/setvars.sh
3. You can find the DAAL sycl samples in the below folder:
cd daal/2021.1-beta09/examples/daal/cpp_sycl
4. Use the makefile to build and run the DAAL examples, You can try any of the below commands:
  • make libintel64 example=pca_cor_dense_batch
[Now, it will build by Intel(R) oneAPI Compiler (as default) and run pca example for 64-bit applications and do static linking]
  • make sointel64 example=pca_cor_dense_batch
[build by Intel(R) oneAPI Compiler (as default) and run pca example for Intel(R)64 processor family applications, dynamic linking]
  • make libintel64 [To build and run all the samples via static linking]
  • make sointel64 [To build and run all the samples via dynamic linking]
Hopes this helps for you. Please reach out to us in case of any issues/queries.
Chithra
Ajmeer_Khan
Hi Chitra,
Thanks for your answer.I will check this .I have another question.
will oneDAL support FPGA?
ChithraJ_Intel
Hi Ajmeer,
Chithra
Ajmeer_Khan
Hi Chitra,
Yes Chitra .I am able to compile and run oneDAL with dpc++ but I am not able to compile the code for FPGA. So that I have posted this question separately. You can close this thread. Thanks for your support.
ChithraJ_Intel
Hi Ajmeer,
Thanks for the confirmation. We would discontinue monitoring this thread. Please feel free to raise a new thread if you need further assistance.
Chithra
