Hi Ajmeer,
Please let us know whether your issue is resolved or not. Are you able to run oneDAL sample with DPC++ complier? If so, can we discontinue monitoring this thread?
Regarding the FPGA support, we could observe that you have a different thread with similar content and will address your issue in that thread. Link: https://community.intel.com/t5/Intel-oneAPI-Data-Analytics/Compiling-oneDAL-library-with-dpc/m-p/1211439#M815
Chithra
Hi Ajmeer,
Could you please follow the below steps to build the DAAL samples with DPC++ complier:
1. Copy the daal folder from inteloneapi folder which is preinstalled in Devcloud to your home folder:
cp -r /opt/intel/inteloneapi/daal /home/uxxxxx/
2. Setting up oneAPI environment via setvars.sh script:
source /opt/intel/inteloneapi/setvars.sh
3. You can find the DAAL sycl samples in the below folder:
cd daal/2021.1-beta09/examples/daal/cpp_sycl
4. Use the makefile to build and run the DAAL examples, You can try any of the below commands:
- make libintel64 example=pca_cor_dense_batch
[Now, it will build by Intel(R) oneAPI Compiler (as default) and run pca example for 64-bit applications and do static linking]
- make sointel64 example=pca_cor_dense_batch
[build by Intel(R) oneAPI Compiler (as default) and run pca example for Intel(R)64 processor family applications, dynamic linking]
- make libintel64 [To build and run all the samples via static linking]
- make sointel64 [To build and run all the samples via dynamic linking]
Hopes this helps for you. Please reach out to us in case of any issues/queries.
Chithra
Hi Chitra,
Thanks for your answer.I will check this .I have another question.
will oneDAL support FPGA?
Hi Ajmeer,
Chithra
Hi Chitra,
Yes Chitra .I am able to compile and run oneDAL with dpc++ but I am not able to compile the code for FPGA. So that I have posted this question separately. You can close this thread. Thanks for your support.
- Tags:
- e
Hi Ajmeer,
Thanks for the confirmation. We would discontinue monitoring this thread. Please feel free to raise a new thread if you need further assistance.
Chithra
