hidden text to trigger early load of fonts ПродукцияПродукцияПродукцияПродукция Các sản phẩmCác sản phẩmCác sản phẩmCác sản phẩm المنتجاتالمنتجاتالمنتجاتالمنتجات מוצריםמוצריםמוצריםמוצרים
Intel® oneAPI Data Analytics Library
Learn from community members on how to build compute-intensive applications that run efficiently on Intel® architecture.
Lipschitz constant for logistic loss function
Gusev__Dmitry
初学者
5,389 次查看
Can anyone please help and verify the  Lipschitz constant formula at the bottom of  the page  https://software.intel.com/en-us/daal-programming-guide-logistic-loss ?
Currently, in the Developer Guide document the upper bound for logistic loss Lipschitz constant is specified as max||xi||2 + λ2/n
However,  it could be shown that logistic loss Hessian spectral norm upper bound (rough) is rather max||xi||22 + λ
Your clarification  is much appreciated.
Dmitry
0 项奖励
4 回复数
AthiraM_Intel
主持人
5,389 次查看
We are forwarding this case to technical experts.They will assist you shortly.
0 项奖励
Kirill_S_Intel
5,389 次查看
Hello, Dmitry
Thanks for reporting this statement! Seems instead of  max||xi||2  we should use  max||xi||22 , it was misprint.
λ2 scaling was  done to align sklearn regularization penalty value. (https://github.com/scikit-learn/scikit-learn/blob/master/sklearn/linear_model/_sag.py#L78)
Note: Lipschitz constant is used only for SAGA algorithm, for calculation optimal step size.
https://hal.inria.fr/hal-00860051/document
Kirill
0 项奖励
Gusev__Dmitry
初学者
5,389 次查看
Hi Kirill,
Thanks for getting back to me.
Couple of thoughts about  Lipschitz constant:
  1. Please note, that in the formula for logistic loss (https://software.intel.com/en-us/daal-programming-guide-logistic-loss) the regularization term is not divided by n, as the preceding sum term.  As a result, if you plug in zero design matrix into the formula(with no intercept), you will get Hessian exactly 2*λ*E and norm of the Hessian is 2*λ - it is a sharp upper bound. Obviously,  λ/n is less than 2* λ. (In my first post I omitted multiplier 2 since normally quadratic term is divided by 2)
  2. In the original paper https://arxiv.org/pdf/1407.0202.pdf the L2 regularization term is a part of sum, as it is a smooth component and therefore divided by n. That could be the source of λ/n term.
  3.  The max||x||2 is a pretty much rough upper bound for the Lipschitz constant. As a result, the step size is small and the convergence rate may not be optimal.  In my experiments decreasing Lipschitz constant may improve SAGA algorithm performance.
I would like to know your opinion, since I am implementing a custom objective function for the SAGA algorithm and looking for high performance computing with large data sets.
Dmitry.
0 项奖励
Kirill_S_Intel
5,389 次查看
Hello, Dmitry
Currently, algorithm supports parameter 'learningRateSequence' (https://software.intel.com/en-us/daal-programming-guide-computation-13), if we see some performance improvements with another step size, DAAL library provides options to use this advantages. For reason of conformance with sklearn library we can`t change this automatic step selection, however 'learningRateSequence' parameter is provided.
About source of scaling λ term by n  I think it make sense.
Kirill
0 项奖励
回复
