Intel® oneAPI Data Analytics Library
Learn from community members on how to build compute-intensive applications that run efficiently on Intel® architecture.
230 Discussions
Not able to convert training data using HomogenNumericTable
banerjee__Shayantan
I am trying to run SVM on a dataset using DAAL. I have split the data into train/test and then when I apply HomogenNumeric() on it, I get the following error. Need some help solving this
from sklearn.model_selection import StratifiedShuffleSplit
sss = StratifiedShuffleSplit(n_splits=1, test_size=0.3, random_state=1)
sss.get_n_splits(X_vitals, y_vitals)
for train_index, test_index in sss.split(X_vitals, y_vitals):
    print("TRAIN:", train_index, "TEST:", test_index)
    X_train, X_test = X_vitals.iloc[train_index], X_vitals.iloc[test_index]
    y_train, y_test = y_vitals.iloc[train_index], y_vitals.iloc[test_index]
HomogenNumericTable(X_train)
The following is the error:
NotImplementedError                       Traceback (most recent call last)
<ipython-input-218-f4f9b7de9bcf> in <module>()
----> 1 HomogenNumericTable(X_train)
/home/shayantan/miniconda3/envs/intelpython/lib/python3.5/site-packages/daal/data_management/__init__.py in __new__(cls, *args, **kwargs)
   4407                 *args, **kwargs):
   4408         if 'ntype' not in kwargs or kwargs['ntype'] == float64:
-> 4409             return HomogenNumericTable_Float64(*args)
   4410         if 'ntype' in kwargs and kwargs['ntype'] == float32:
   4411             return HomogenNumericTable_Float32(*args)
/home/shayantan/miniconda3/envs/intelpython/lib/python3.5/site-packages/daal/data_management/__init__.py in __init__(self, *args)
   2698
   2699
-> 2700         this = _data_management.new_HomogenNumericTable_Float64(*args)
   2701         try:
   2702             self.this.append(this)
NotImplementedError: Wrong number or type of arguments for overloaded function 'new_HomogenNumericTable_Float64'.
  Possible C/C++ prototypes are:
    daal::data_management::interface1::HomogenNumericTable< double >::HomogenNumericTable(daal::data_management::interface1::NumericTableDictionary *)
    daal::data_management::interface1::HomogenNumericTable< double >::HomogenNumericTable(daal::services::SharedPtr< daal::data_management::interface1::NumericTableDictionary >)
    daal::data_management::interface1::HomogenNumericTable< double >::HomogenNumericTable(double *const,size_t,size_t)
    daal::data_management::interface1::HomogenNumericTable< double >::HomogenNumericTable()
    daal::data_management::interface1::HomogenNumericTable< double >::HomogenNumericTable(daal::data_management::interface1::DictionaryIface::FeaturesEqual,double *const,size_t,size_t)
    daal::data_management::interface1::HomogenNumericTable< double >::HomogenNumericTable(daal::data_management::interface1::DictionaryIface::FeaturesEqual,double *const,size_t)
    daal::data_management::interface1::HomogenNumericTable< double >::HomogenNumericTable(daal::data_management::interface1::DictionaryIface::FeaturesEqual,double *const)
    daal::data_management::interface1::HomogenNumericTable< double >::HomogenNumericTable(daal::data_management::interface1::DictionaryIface::FeaturesEqual)
    daal::data_management::interface1::HomogenNumericTable< double >::HomogenNumericTable(double *const,size_t,size_t,double const &)
    daal::data_management::interface1::HomogenNumericTable< double >::HomogenNumericTable(daal::data_management::interface1::DictionaryIface::FeaturesEqual,double *const,size_t,size_t,double const &)
    daal::data_management::interface1::HomogenNumericTable< double >::HomogenNumericTable(size_t,size_t,daal::data_management::interface1::NumericTableIface::AllocationFlag)
    daal::data_management::interface1::HomogenNumericTable< double >::HomogenNumericTable(daal::data_management::interface1::DictionaryIface::FeaturesEqual,size_t,size_t,daal::data_management::interface1::NumericTableIface::AllocationFlag)
    daal::data_management::interface1::HomogenNumericTable< double >::HomogenNumericTable(size_t,size_t,daal::data_management::interface1::NumericTable::AllocationFlag,double const &)
    daal::data_management::interface1::HomogenNumericTable< double >::HomogenNumericTable(daal::data_management::interface1::DictionaryIface::FeaturesEqual,size_t,size_t,daal::data_management::interface1::NumericTable::AllocationFlag,double const &)
