Can someone help me to understand why I am getting numerical results with DAAL which I would not expect:
I am running sgd_log_loss_dense_batch project. I changed datasetFileName to point to very simple logistic regression input:
1,0
2,0
3,0
4,0
5,1
6,0
7,1
8,0
9,1
10,1
Expected coefficients are
(Intercept) V1
-4.3578 0.6622
However output of sgd_log_loss_dense_batch is not even close to it and depends significantly on initial approximation. For instance if initialPoint[nFeatures + 1] = {0, 0}; it hits max iteration limit (1000 iteration) and the output is
Minimum:
-1.111
0.127
Number of iterations performed:
1000.000
With initialPoint[nFeatures + 1] = {1, 1}; It stops after first iteration and the output is
Minimum:
0.990
0.971
1.000
Your help is much appreciated,
Dmitry.
Hello Dmitry,
As you pointed sgd (default dense method) reached maximum iteration (nIterations = 1000). If you increase this value (nIterations=10000) you get much closer solution.
Also do not forget to decrease 'accuracyThreshold' to get even better solution (does not depend on initial point).
Try with this initial values:
const size_t nIterations = 10000000;
const size_t nFeatures = 1;
const float learningRate = 0.001f;
const double accuracyThreshold = 0.00002;
float initialPoint[nFeatures + 1] = {0,0}; // {1,1} no difference
result:
Minimum:
-4.383
0.652
10000000.000
Such behavior is due to not automatic step size selection (you should pick up it correctly), and sgd defaultDense method consider only one sample on each iteration (batchSize = 1). To get smaller number of iterations use 'minibatch' or 'momentum' methods of sgd solver (examples: sgd_moment_dense_batch.cpp, sgd_mini_dense_batch.cpp).
To summarize: use smaller value for 'accuracyThreshold'; pick up step size correctly for sgd solver.
Kirill
