Intel® oneAPI Data Analytics Library
Learn from community members on how to build compute-intensive applications that run efficiently on Intel® architecture.
230 Discussions
ODR violation attempting to link more than one object that included daal.h
Graham_M_
If I create a file, a.cpp:
#include "daal.h"
void f() { return; }
and another file, b.cpp:
#include "daal.h"
void g() { return; }
then when I attempt to compile and link them with:
g++ a.cpp -I/opt/intel/compilers_and_libraries_2016.0.069/linux/daal/include -c -fPIC
g++ b.cpp -I/opt/intel/compilers_and_libraries_2016.0.069/linux/daal/include -c -fPIC
g++ -shared -o ab.so a.o b.o
then the following error is produced:
b.o: In function `void daal::data_management::DataSource::allocateNumericTableImpl<daal::data_management::AOSNumericTable>(daal::data_management::AOSNumericTable**)':
b.cpp:(.text+0x0): multiple definition of `void daal::data_management::DataSource::allocateNumericTableImpl<daal::data_management::AOSNumericTable>(daal::data_management::AOSNumericTable**)'
a.o:a.cpp:(.text+0x0): first defined here
b.o: In function `void daal::data_management::DataSource::allocateNumericTableImpl<daal::data_management::SOANumericTable>(daal::data_management::SOANumericTable**)':
b.cpp:(.text+0xa0): multiple definition of `void daal::data_management::DataSource::allocateNumericTableImpl<daal::data_management::SOANumericTable>(daal::data_management::SOANumericTable**)'
a.o:a.cpp:(.text+0xa0): first defined here
collect2: error: ld returned 1 exit status
Should I expect to be able to include daal.h in more than one source file? If so, is there a way around this error?
For reference, I am using this G++ version:
$ g++ --version
g++ (Debian 4.9.2-10) 4.9.2
Many thanks,
Graham.
Graham_M_
As a workaround, declaring those two functions in include/data_management/connectors/data_source.h inline suppresses the issue:
template<>
inline void DataSource::allocateNumericTableImpl(AOSNumericTable **nt)
    size_t nFeatures = _dict->getNumberOfFeatures();
    size_t structureSize = getStructureSize();
    *nt = new AOSNumericTable(structureSize, nFeatures, 0);
    setNumericTableDictionary(*nt);
template<>
inline void DataSource::allocateNumericTableImpl(SOANumericTable **nt)
    *nt = 0;
Ilya_B_Intel
Thanks, Graham!
We fixed that in internal code base.
Alvin_S_
Minor cleanup required in soa_numeric_table.h on line 291 in allocateDataMemory().
Has "return;" two lines in a row.
ACS
Andrey_N_Intel
Thank you, Alvin, for the catch! We will remove it. Andrey
