Intel® oneAPI Data Analytics Library
Learn from community members on how to build compute-intensive applications that run efficiently on Intel® architecture.
Pipelines in DAAL
Matt_P_1
I'm looking to set up an online-learning pipeline in DAAL, and would like to replicate existing (working) scikit-learn code I have built around their Pipeline object. Is there a similar object in pyDAAL, and if so can anyone point me to a code containing it?
Thanks!
Matt
Sergey_M_Intel2
Hi Matt,
Can you give an example how your pipeline looks like? What transforms does it involve?
Sergey Maidanov
Matt_P_1
Sorry for the slow reply. The current workflow involves multiple LabelEncoder (one applied to each of a list of columns), a StandardScaler, and an SVM algorithm.
Matt_P_1
Hi Sergey -
Any update on this?
Thanks!
Matt
Nathan_G_Intel
Matt,
I'm assuming you mean the class sklearn.pipeline.Pipeline.
No DAAL does not have an equivalent pipeline class. However sklearn allows for custom transformers to be inserted into their pipeline object. The custom transformer is an object you create yourself, with the requirement of "fit" and "transform" methods.
You can build a smaller wrapper object around DAAL algo object, and insert it into sklearn's pipeline as a custom transformer.
There is a nice blog about this here:
https://opendevincode.wordpress.com/2015/08/01/building-a-custom-python-scikit-learn-transformer-for-machine-learning/
