Intel® oneAPI Data Analytics Library
Learn from community members on how to build compute-intensive applications that run efficiently on Intel® architecture.
223 Discussions
Problems with DAAL, etc. Visual Studio 2015 Integration
Aaron_R_
Hi, I've been trying to get acclimated with Intel's release of several academic focused compiler and software tools. I'm in the process of messing around with the libraries and I think there is a problem with the integration of the installed tool and Microsoft Visual Studio 2015. Although I do see the options for working with Intel's software tools, etc. it doesn't seem as if I can select that I would like to use the Intel compiler like when it is already specified in the example files. After messing around with it for some time within visual studio 2015, etc. I decided that there might be something within the installation directory that I could use to configure the compiler and variables if a system variable or something wasn't configured properly. Unfortunately, running the bat file located in C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2016\windows\bin throws an error indicating that the script has trouble determining the location of Visual Studio's Common Tools. I would like to get this configured and running with the version of Visual Studio 2015 I am running (Visual Studio 2015 Community Edition). If there are some system variables it might be beneficial to set or useful visual studio configurations I would appreciate hearing them.
Zhang_Z_Intel
Please take a look at this article about "Getting Started with Intel DAAL for Windows": https://software.intel.com/en-us/get-started-with-daal-for-windows
Although the discussion is not about using Visual Studio 2015 per se, there is good information you can use to configure your IDE.
