Intel® oneAPI Data Analytics Library
Learn from community members on how to build compute-intensive applications that run efficiently on Intel® architecture.
Quality Metric Set (Intel® DAAL 2017 Beta)
Mariana_O_
I need to use binary confusion matrix, but it only works for me with SVM.
When I use it with Naive Bayes or Adaboost I get an error when I try to set predicted labels or ground truth labels to this input: input = qualityMetricSet.getInputDataCollection().getInput(quality_metric_set.confusionMatrix)
What am I doing wrong?
Mariana
VictoriyaS_F_Intel
Hello Mariana,
Here is an example of binary confusion matrix computation for AdaBoost algorithm:
 //  Content:
 //     Java example of AdaBoost quality metrics
package com.intel.daal.examples.quality_metrics;
import java.nio.DoubleBuffer;
import com.intel.daal.algorithms.adaboost.Model;
import com.intel.daal.algorithms.adaboost.prediction.*;
import com.intel.daal.algorithms.adaboost.training.*;
import com.intel.daal.algorithms.adaboost.quality_metric_set.*;
import com.intel.daal.algorithms.classifier.prediction.ModelInputId;
import com.intel.daal.algorithms.classifier.prediction.NumericTableInputId;
import com.intel.daal.algorithms.classifier.prediction.PredictionResult;
import com.intel.daal.algorithms.classifier.prediction.PredictionResultId;
import com.intel.daal.algorithms.classifier.quality_metric.binary_confusion_matrix.*;
import com.intel.daal.algorithms.classifier.training.InputId;
import com.intel.daal.algorithms.classifier.training.TrainingResultId;
import com.intel.daal.data_management.data.NumericTable;
import com.intel.daal.data_management.data.HomogenNumericTable;
import com.intel.daal.data_management.data.MergedNumericTable;
import com.intel.daal.data_management.data_source.DataSource;
import com.intel.daal.data_management.data_source.FileDataSource;
import com.intel.daal.examples.utils.Service;
import com.intel.daal.services.DaalContext;
class AdaBoostTwoClassQualityMetricSetBatch {
    /* Input data set parameters */
    private static final String trainDataset = "../data/batch/adaboost_train.csv";
    private static final String testDataset  = "../data/batch/adaboost_test.csv";
    private static final int nFeatures     = 20;
    private static TrainingResult   trainingResult;
    private static PredictionResult predictionResult;
    private static ResultCollection qualityMetricSetResult;
    private static NumericTable groundTruthLabels;
    private static NumericTable predictedLabels;
    private static DaalContext context = new DaalContext();
    public static void main(String[] args) throws java.io.FileNotFoundException, java.io.IOException {
        trainModel();
        testModel();
        testModelQuality();
        printResults();
        context.dispose();
    private static void trainModel() {
        /* Retrieve data from the input data sets */
        FileDataSource trainDataSource = new FileDataSource(context, trainDataset,
                DataSource.DictionaryCreationFlag.DoDictionaryFromContext,
                DataSource.NumericTableAllocationFlag.NotAllocateNumericTable);
        /* Create Numeric Tables for training data and labels */
        NumericTable trainData = new HomogenNumericTable(context, Double.class, nFeatures, 0, NumericTable.AllocationFlag.NotAllocate);
        NumericTable trainGroundTruth = new HomogenNumericTable(context, Double.class, 1, 0, NumericTable.AllocationFlag.NotAllocate);
        MergedNumericTable mergedData = new MergedNumericTable(context);
        mergedData.addNumericTable(trainData);
        mergedData.addNumericTable(trainGroundTruth);
        /* Retrieve the data from an input file */
        trainDataSource.loadDataBlock(mergedData);
        /* Create algorithm objects to train the AdaBoost model */
        TrainingBatch algorithm = new TrainingBatch(context, Double.class, TrainingMethod.defaultDense);
        /* Pass a training data set and dependent values to the algorithm */
        algorithm.input.set(InputId.data, trainData);
        algorithm.input.set(InputId.labels, trainGroundTruth);
        /* Train the AdaBoost model */
        trainingResult = algorithm.compute();
    private static void testModel() {
        FileDataSource testDataSource = new FileDataSource(context, testDataset,
        /* Create Numeric Tables for testing data and labels */
        NumericTable testData = new HomogenNumericTable(context, Double.class, nFeatures, 0, NumericTable.AllocationFlag.NotAllocate);
        groundTruthLabels = new HomogenNumericTable(context, Double.class, 1, 0, NumericTable.AllocationFlag.NotAllocate);
        mergedData.addNumericTable(testData);
        mergedData.addNumericTable(groundTruthLabels);
        testDataSource.loadDataBlock(mergedData);
        /* Create algorithm objects for AdaBoost prediction with the fast method */
        PredictionBatch algorithm = new PredictionBatch(context, Double.class, PredictionMethod.defaultDense);
        /* Pass a testing data set and the trained model to the algorithm */
        Model model = trainingResult.get(TrainingResultId.model);
        algorithm.input.set(NumericTableInputId.data, testData);
        algorithm.input.set(ModelInputId.model, model);
        /* Compute prediction results */
        predictionResult = algorithm.compute();
    private static void testModelQuality() {
        /* Retrieve predicted labels */
        predictedLabels = predictionResult.get(PredictionResultId.prediction);
        /* Create a quality metric set object to compute quality metrics of the AdaBoost algorithm */
        QualityMetricSetBatch quality_metric_set = new QualityMetricSetBatch(context);
        BinaryConfusionMatrixInput input = quality_metric_set.getInputDataCollection()
                .getInput(QualityMetricId.confusionMatrix);
        input.set(BinaryConfusionMatrixInputId.predictedLabels, predictedLabels);
        input.set(BinaryConfusionMatrixInputId.groundTruthLabels, groundTruthLabels);
        /* Compute quality metrics */
        qualityMetricSetResult = quality_metric_set.compute();
    private static void printResults() {
        /* Print the classification results */
        Service.printClassificationResult(groundTruthLabels, predictedLabels, "Ground truth", "Classification results",
                "AdaBoost classification results (first 20 observations):", 20);
        /* Print the quality metrics */
        BinaryConfusionMatrixResult qualityMetricResult = qualityMetricSetResult
                .getResult(QualityMetricId.confusionMatrix);
        NumericTable confusionMatrix = qualityMetricResult.get(BinaryConfusionMatrixResultId.confusionMatrix);
        NumericTable binaryMetrics = qualityMetricResult.get(BinaryConfusionMatrixResultId.binaryMetrics);
        Service.printNumericTable("Confusion matrix:", confusionMatrix);
        DoubleBuffer qualityMetricsData = DoubleBuffer
                .allocate((int) (binaryMetrics.getNumberOfColumns() * binaryMetrics.getNumberOfRows()));
        qualityMetricsData = binaryMetrics.getBlockOfRows(0, binaryMetrics.getNumberOfRows(), qualityMetricsData);
        System.out.println("Accuracy:      " + qualityMetricsData.get(BinaryMetricId.accuracy.getValue()));
        System.out.println("Precision:     " + qualityMetricsData.get(BinaryMetricId.precision.getValue()));
        System.out.println("Recall:        " + qualityMetricsData.get(BinaryMetricId.recall.getValue()));
        System.out.println("F-score:       " + qualityMetricsData.get(BinaryMetricId.fscore.getValue()));
        System.out.println("Specificity:   " + qualityMetricsData.get(BinaryMetricId.specificity.getValue()));
        System.out.println("AUC:           " + qualityMetricsData.get(BinaryMetricId.AUC.getValue()));
It works fine and produces following output:
Confusion matrix:
401.000   0.000
0.000    1599.000
Accuracy:      1.0
Precision:     1.0
Recall:        1.0
F-score:       1.0
Specificity:   1.0
AUC:           1.0
Regarding Naive Bayes classifier. It is a multi-class classifier and binary confusion matrix could not be used with Naive Bayer algorithm. Please use multi-class confusion matrix instead. Please refer to SVMMulticlassQualityMetricSetBatchExample.java example for the details.
Victoriya
