Intel® oneAPI Data Analytics Library
Learn from community members on how to build compute-intensive applications that run efficiently on Intel® architecture.
223 Discussions
Question regarding daal covariance function C++
martin_z
I have an array (double*) that represents some timeseries.
I use this array for several computations with the intel MKL library.
After these computations I would like to calculate
a covariance matrix (based on the data in the array) with help of the
DAAL covariance function (covariance::Batch).
If my understanding of the documentation is correct, I need a
Pointer to a NumericTable Object that I would have to pass
to a covariance::Batch object.
I am not sure how I can create a NumericTable Object with
data from an double* array.
Could someone explain this to me in more detail ?
Documentation was not helpful so far to answer these question.
Kind regards
ArunJ_Intel
Hi Martin,
Forwarding your case to SME. They will get back to you soon regarding this.
Arun Jose
ArunJ_Intel
Hi Martin,
Arun Jose
