Intel® oneAPI Data Analytics Library
Learn from community members on how to build compute-intensive applications that run efficiently on Intel® architecture.
Ridge regression - loss of accuracy between Composer 2017 up4 and 2018 up3
Guillaume_A_
I notice a loss of accuracy and some unexpected crashes of the ridge regression learning when updating Composer from 2017 up4 to 2018 up3
Here is my code:
int ridgeLearn(double* ouputRegressionCoeffs, double* const trainingFeatureSamples, int nTrainingFeatures, double* const trainingTargetValues, int nTrainingSamples, double regularizationPar)
  const NumericTablePtr featureSamplesTable(new HomogenNumericTable<double>(trainingFeatureSamples, nTrainingFeatures, nTrainingSamples));
  const NumericTablePtr targetValuesTable(new HomogenNumericTable<double>(trainingTargetValues, 1, nTrainingSamples));
  algorithms::ridge_regression::training::Batch<> algorithm;
  // Pass a training data set to the algorithm
  algorithm.input.set(algorithms::ridge_regression::training::data, featureSamplesTable);
  algorithm.input.set(algorithms::ridge_regression::training::dependentVariables, targetValuesTable);
  // Ridge model config
  const auto regularizationParTbl = new double[1]; regularizationParTbl[0] = regularizationPar;
  const NumericTablePtr ridgeParameter(new HomogenNumericTable<double>(regularizationParTbl, 1, 1));
  algorithm.parameter.ridgeParameters = ridgeParameter;
  // Composer 2018
  auto status = algorithm.compute(); bool isOk = status.ok();
  // Composer 2017
  algorithm.compute(); bool isOk = algorithm.getErrors()->isEmpty();
  if(isOk)
    const SharedPtr<algorithms::ridge_regression::training::Result> result = algorithm.getResult();
    NumericTablePtr resultCoeffs = result->get(algorithms::ridge_regression::training::model)->getBeta();
    BlockDescriptor<double> block;
    resultCoeffs->getBlockOfRows(0, resultCoeffs->getNumberOfRows(), readOnly, block);
    memcpy(ouputRegressionCoeffs, block.getBlockPtr(), block.getNumberOfColumns() * sizeof(double));
  delete[] regularizationParTbl;
  return isOk ? 1:0;
void RidgeRegressionTest0()
  int nRows = 10;
  int nCols = 2;
  double * features = new double[nRows * nCols];
  double * labels = new double[nRows];
  for (int i = 0; i < nRows; ++i)
    features[i * nCols]     = i + 1.0;  // x1
    features[i * nCols + 1] = i + 1.0;  // x2
    labels               = 4.0*(i+1);    // 0.0 + 4.0*x
  double * beta = new double[nCols + 1];
  int statusResult = ridgeLearn(beta, features, nCols, labels, nRows, 1e-7);
  printf("Compute status: %d\n", statusResult);
  printf("result:\t%.16lf\t%.16lf\t%.16lf\n", beta[0], beta[1], beta[2]);
  printf("expect:\t%.16lf\t%.16lf\t%.16lf\n", 0.0, 2.0, 2.0);
  delete[] features;
  delete[] labels;
  delete[] beta;
void RidgeRegressionTest1()
  int nRows = 10;
  int nCols = 2;
    features[i * nCols + 1] = (i + 1.0) *(i + 1.0);                 // x2^2
    labels               = 3.0 * (i + 1) + (i + 1.0)*(i + 1.0);  // 0.0 + 3.0*x + x^2
  printf("expect:\t%.16lf\t%.16lf\t%.16lf\n", 0.0, 3.0, 1.0);
  delete[] features;
  delete[] labels;
  delete[] beta;
RidgeRegressionTest0() should return : beta[0] = 0.0, beta[1] = 2.0, beta[2] = 2.0      (y = 0 + 4x)
  • Composer 2017 outputs are good:  beta[0] = 0.0000000133333383    beta[0] = 2.0000009558174350    beta[0] = 1.999999041758322
  • Composer 2018 returns an error: "Failed to solve the system of normal equations"
RidgeRegressionTest1() should return : beta[0] = 0.0, beta[1] = 3.0, beta[2] = 1.0       (y = 0 + 3x + x^2)
  • Composer 2017 outputs are good:             beta[0] = 0.0000001533332496    beta[0] = 2.9999999296970059   beta[0] = 1.0000000060606029
  • Composer 2018 outputs are not so good:  beta[0] = -0.0001530328445369   beta[0] = 3.0000724792480469   beta[0] = 0.9999936223030090
Are my inputs wrong for the new version ?
Can someone help me ?
My configuration:
  • Composer 2017.4.210 and 2018.3.210
  • BasePlatformToolset = V120
  • Windows 10 Entreprise (version 1703, OS build 15063.1155)
  • i7-6820HQ
Guillaume A.
Gennady_F_Intel
this happens because of since DAAL 2018 the default precision has been changed since double to float.
Gennady_F_Intel
thanks Guillaume, we will check the problem on our side and  back asap.
Gennady_F_Intel
Guillaume_A_
That was obvious, my bad ...
Thanks you !
